| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 | |
Banned
By diamond do you mean a quad? This is just a variation on a fan dipole or capacitive-loaded dipole, it gives a bit of length over the feed-to-end length due to capacitive loading and some broadbanding. You'd get more broadbanding if you brought the split point closer to the centre and made the 'wings' thinner isosceles triangles instead of diamonds. For a quad you need to connect to the open ends. The fact that you're picking up anything is down to signal strength and blind luck. You've got no idea what the impedance is at the feed point. You could 'design' it by looking at a local Yagi and pulling the dipole to size by eye. A bit shorter than the 'driven' element. You'd probably get a better match to the co-ax without a transformer, it'll be ~75ohms @ 1/2 wavelength. w |
#12 | ||
For those that are not familiar with a spectrum analyzer, I offer this simple explanation. An oscilloscope displays amplitude VS time. Both scales are usually linear. A spectrum analyzer displays amplitude VS frequency. The amplitude scale is usually logrithmic (in dB's). The FFT analyzer often used to display harmonic spectra IS a spectrum analyzer. The FFT analyzer we are used to works at audio frequencies, but they are available into the GHz range. My RF spectrum analyzer is an old tech swept LO analyzer. It goes from 0 to 1250 MHz. The first observation I got when I connected the coat hanger antenna to the spectrum analyzer was a surprise to see strong signals from 88 MHz all the way up to 930 MHz. The first photo shows the FM broadcast band (88 to 108 MHz). There were many strong signals in the -50 to -60 dbm range. The second photo shows the VHF high TV band (174 to 216 MHz). Channels 7, 10, 12 and 13 are visible. 7 and 10 are Miami channels, 12 and 13 are in West Palm Beach. The third photo shows a portion of the UHF TV band (470 to 698 MHz). Channels 18, 19, 20, 22, and 23 are visible.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#13 | ||||
The first photo shows the upper end of the UHF TV band. Channels 46, 47, 48 and 50 are visible. Channels 44 and 51 are in the noise. They can be seen at narrower span and bandwidth settings. The second photo shows a few SMR carriers around 865 MHz, two WCDMA channels in the 870 to 880 MHz range and a few cellular carriers above them. They are from a cell site about 2 miles away. There are some paging carriers in the 930 to 931 MHz range not shown.
#14 |
Given that you are using it over a frequency range of 4:1 the transformer is probably helping, on average. You may get 75ohms at the first half-wave resonance, which the transformer will change to 19ohms but at the full-wave resonance you could get many hundred ohms (or more) so the transformer will bring it down.
I agree with your comments about many TV antennas: modern manufacturers seem to come up with some pretty arrangement of wires and then try to make up for the awful performance by adding a preamp (which could easily make things worse by adding intermodulation). My guess is that in your situation the right answer is some variant of the fat dipole or discone, although 4:1 may require some form of log-periodic structure. |
#15 |
Banned
If you want horizontal polarisation then a biconical arrangement will do 3 octaves, maybe 4. and give you a constant impedance, probably not too bad a match to 75 ohms. You can build it with a wire frame if you don't exceed 0.2 lambda max spacing. The slant length of the cone is the free-space quarter wavelength at the lowest frequency. Wire all the ends of the 'cone' together. Move the cones in and out to get best response, spacing probably an inch or less at these frequencies, but not critical. Profile of the cone is an equilateral.
w Last edited by wakibaki; 18th April 2011 at 03:44 PM. |
#16 | |||
Many high priced antennas have a rather useless amp. In fact the spectrum analyzer revealed that my Radio Shack "80 channel" distribution amp is actually costing me 3 channels. Time to make a new amp. Connecting the antenna to the TV nets 54 channels. Adding the amp nets 51 chanels. Why? It chops off everything above 620 MHz. The antenna picks up virtually nothing below 50 MHz, but I see all sorts of "stuff" below the FM broadcast band when the amp is inserted. These are intermod and mixing products. The frequency response problem is costing me channel 9. What? Quote:
TV signals in the USA were assigned "channel numbers" spread across 3 "bands" a long time ago. Channel 1 was taken away to become the 6 meter ham band. Channels 2 through 6 (54 to 88 MHz) are in the VHF low band. Channels 7 through 13 (174 to 216 MHz) are in the VHF high band. Channels 14 through 51 (470 to 698 MHz)are UHF. Channels 52 through 69 were taken away with the DTV transition for the 700 MHz commercial, public safety, and high speed data (LTE) bands. Channels 70 through 83 dissapeared 20 years ago to become the 800 MHz cellular, public safety and SMR bands. Along with the DTV transition broadcasters got new frequencies, but kept their old channel numbers. So now the number displayed on your TV bears no resemblance to the actual frequency. The "mapping" of channels to frequencies varies with geographical location. So here channel 9 is broadcast on channel 44, beyond the passband of the Rat Shack amp. Quote:
I am going to concentrate on the amplifier next. I had built one about a year ago using a MMIC from Hittite Microwave. It has a noise figure of 1.1 db, an IIP3 of +20 dbm and a gain of 15 db. It is specified for 550 to 1200 MHz, but has some gain down to 160 MHz. It worked well, but drowned inside my leaky housing. I don't have any more and they are not generally available. They were left over from a work project. There are hundreds of MMIC's out there. I will choose a new one based on IIP3, NF, and gain in that order. Based on what I see on my analyzer I will need a wider frequency range too.
#17 |
With lots of strong signals maybe you need a tube preamp! Your problem is that with such a wide bandwidth you need to worry about IP2 as well as IP3. 6DJ8 running parallel grounded-grid?
I'm sure Wavebourn will have some wonderful Russian military valve he can tell us about! |
#18 |
There aren't many tubes that will have any gain at 700 MHz. The 6DJ8 certainly won't.
Years ago I looked at using a 5670 for a balanced front end in an HF ham radio for intermod reasons but a pair of fets worked better.
#19 |
My suggestion was slightly tongue-in-cheek! Yes, I guess suitable FETs would be best - but do you really need an amp? Since your two directions are back-to-back why not make an antenna with deliberately very poor front-to-back ratio but low sidelobe response? Some sort of vertical stacking to get gain. Two wideband dipoles suitable phased would do the trick.
#20 |
I have had my antenna working for a week now. Thanks George!....now the girls can watch all their soaps in the break room
- Nic |
| DIY FM Antenna | DreadPirate | Everything Else | 9 | 26th March 2011 03:06 AM |
| DIY antenna | Fry-kun | Analog Line Level | 3 | 24th May 2007 08:52 PM |
| amplified tv antenna | karma | Everything Else | 2 | 23rd July 2004 01:48 AM |
| DIY : 27Mhz yagi antenna . | darkm4n | Parts | 6 | 22nd April 2004 11:22 AM |
