| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi everyone,
I'm having a bit of trouble trying to calculate the input resistance of a circuit. The question is: When a 100Mv signal with a 10k internal resistance is connected to the input of the amplifier the input voltage Vi is 67mV. The output voltage Vo with no load connected is 1V. The output voltage with a 1k load is 625mV. Find the input & output resistance of the amplifier? Could someone help with this? Cheers |
#2 |
For the output, draw a voltage divider with two resistors, bottom one with a value of 1k grounded. Pretend the upper one is inside the amp. The upper one still has 1V applied. The midpoint is .625V. Using ohms law, figure out the current through the lower resistor- you know the value and the voltage across it. That same current flows through the upper resistor. Since you know the voltage at both ends (1 and .625) you know the voltage across it. Ohms law again gives you the value, which is the output resistance of the amp. You do the input in basically the same way. For inputs it's actually easier to use a pot and adjust it for 1/2 value on the output compared to the pot shorted or not present. At 1/2 value the input resistance is equal to the pot value.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
Thanks Conrad Hoffman,
I'll give it a go. Thanks again Cheers |
#4 |
You and Conrad implicitly assume a purely resistive input impedance, which is not necessarily the case: often, there also is a significant capacitive component.
In this case, the resistance obtained with this method will yield incorrect results, with theoretically up to 40% error. To check that the impedance is purely resistive, you can make the test at two frequencies, 100Hz and 10KHz f.e. If you find identical values, then it's fine. |
#5 |
This looks like a student homework assignment, not a real world problem.
#6 |
#7 |
#8 |
Yes, homework problems don't have stray capacitance (not until next year, anyway!) and it is difficult to attach a meter to a textbook to measure it at different frequencies.
#9 |
That putting up one's homework problems on an internet forum, then passing off the answers as one's own is cheating. Cheating the instructors, cheating the school, cheating the other students, and most importantly, cheating oneself.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 | |
In practice, knowing "where" to find a solution (or, a method for a solution) is nearly as commendable as knowing "how" to find a solution. Although Tom Lehrer poked fun at the process in "Lobachevsky" (see Lobachevsky Lyrics, and also Lobachevsky video), in fact this same process is at the heart of the "apprentice" system of mastering a trade: the aspiring craftsman starts by performing insignificant portions of a task, but progressively takes on larger portions as the master craftsman guides, instructs, and demonstrates. In that context, nobody accuses the master craftsman of "doing the apprentice's work for him". Conrad Hoffman's reply to the original post isn't bad. He outlined a method, rather than simply stating a formula without explanation. He got bogged down in a verbal explanation when a diagram or two would have been much more effective. ("A picture is worth 1x10^3 words." - but NOTHING beats HARDWARE!) I would have asked the original poster to show his work as far as he could go with the problem - perhaps by posting a schematic of the problem as he understands it. Hopefully, that wouldn't lead all the way back to "What is a Thevenin equivalent source?", but if it does . . . then that's where we start. (It's never too late to learn.) In my experience, the response to that approach is either no response; or "OK - here's what I have, and this is where I don't see the next step"; or, "Just gimme the answer. This is for my Senior Project, and I ain't got time to go through all that fundamentals crap.". From that point, Forum members are pretty good at formulating appropriate responses. "WDCW" (the original poster), would you share a little about yourself and your course of study? Dale p.s. - since the original post showed an Australian flag icon, it was rather obvious that this is a homework question. If it had been from certain other parts of the world, the question may have been from an engineer whose company had just been selected as an out-source for a U.S. or European company that had just awarded bonuses to the managers who fired its engineering staff. |
| 4ohm Resistance | icecoolwas | Car Audio | 7 | 26th May 2008 09:35 AM |
| resistance | impsick | Solid State | 7 | 28th May 2007 04:41 PM |
| how to decide these resistance value.?? | titanchen68 | Solid State | 5 | 29th June 2006 12:50 PM |
| max input resistance for irf610 | AudioGeek | Solid State | 2 | 23rd February 2006 02:22 AM |
| Page generated in 0.19117 seconds (54.64% PHP - 45.36% MySQL) with 10 queries |
