Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 8th April 2011, 09:18 PM   #1
JoeDJ is offline JoeDJ  United States
Default 2 ch stereo to 2ch mono.....?
Is there an easy way to convert 2 ch stereo to 2 ch mono like the option on some amps and receivers?
The reason I ask is because I'm in the process of balancing out my sys and need the exact same siginal fed to both speakers to fine tune it.
Yes, I know, just feed a mono siginal to them.
However there are program contents that iI want to use that is only avalible in stereo. I like to use specefic program content as one tool to set up a sys becase I'm very familiar with exactly how they are supposed to sound.
Old 8th April 2011, 11:37 PM   #2
purplepeople's Avatar
The time honoured method is to use a summing amp or the guts of a mixer. If you have some good opamps handy, you'll need at least one as a buffer with both channels fed to the input. If you want to vary the balance, you'll need at least 3 with each input getting it's own opamp buffer both going into a the last opamp buffer. It helps to know the output impedance of your source and the input impedance of your amp to match.
If your source is digital and you can mess around in a computer, there are programs that can digitally sum the two into mono.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 9th April 2011, 01:13 AM   #3
........If your source is digital and you can mess around in a computer, there are programs that can digitally sum the two into mono.
Of course!
I got just the program that can do that. Even good ol' Winamp can convert an audio file into a mono wav and from there, it's a simple step to convert it into the audio file of choice with various programs.
Sometimes, this old brain of mine needs a swift kick in the frontal lobes to get it going.
Old 9th April 2011, 01:49 AM   #4
Or you could use a digital audio editor to make a mono signal source whether it be noise, tones or mono mix of music. I know this can be done in CoolEdit / Audition. I believe it can be done in Audacity though I don't use it myself. This would certainly be the cheapest and quickest way to get a mono mix - assuming Audacity can do this - and burn yourself a CD. I make test discs frequently for calibrating, tuning, measuring or whatever you like.
stereo to mono jpd123 PC Based 10 3rd February 2012 06:52 AM
Stereo to mono... mcelaj Solid State 12 17th December 2011 04:57 PM
Need high quality 200w/Ch. @ 8ohms stereo amp Thabto Solid State 3 10th February 2011 07:25 AM
amp: 4-ch ... stereo with adjustable xover?? albireo13 Solid State 8 22nd July 2010 07:21 AM
stereo to mono janey Solid State 3 12th December 2001 05:57 AM
Page generated in 0.07793 seconds (69.17% PHP - 30.83% MySQL) with 10 queries
