Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th March 2011, 03:48 AM   #1
Eric is offline Eric  United States
Eric's Avatar
Default Need advice for DIY surge supression
I'm working on a DIY "power center" for my basement theater system that will be hard-wired to the 120v breaker box in the house. It will feature balanced power (60-0-60vac) for the front end (preamp, cd, dvd), have EMI/RFI power filtering, and time-delayed AC outlets that are controlled by heavy-duty relays that are controlled by the DC Triggers on my preamp.
The only thing missing is over-voltage protection. I've been searching the web trying to learn more and it seems that many designs feature multiple MOVs and Gas Discharge Tubes (a series of 2-4 MOVs followed by a similar number of GDTs).
I have a few questions about these devices and how they are used. If I use multiple MOVs, what rating is appropriate? Are all MOVs rated at the same specs, or are the ratings staggered as you move through the "chain" ? The same set of questions applies to Gas Discharge Tubes: How many is ideal to use? What ratings are appropriate? Are they all the same or somehow staggered?
I also came across some discussion of TransZorb Diodes and Crowbar Circuits, but these seem to apply to DC power supplies....
Can someone help me fill in the gaps here?
Thanks,
Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 29th March 2011, 06:24 PM   #2
MOV's are just paralleled across the line.
When I lived in Fla. I used to work in a T.V. repair shop and we made are money in the summer during lightening season.
I very very rarely ever seen a MOV not do It's job.
I believe there are a few different voltage ranges to choose from around 200v and above as it has been a while since I have looked up any specs on them.
But usualy lightening will just blowup the MOV and/or fuse and maybe a diode and thats it.
However, you can't stop lightening and I have seen it do a whole lot more than just blow up the MOV.
But they are a very cheap form of protection and a wise investment. jer
Old 29th March 2011, 10:37 PM   #3
Speedskater's Avatar
Or then you could get a store bought unit that mounts inside your breaker box (like a dual breaker) for under $100 US and installs in 5 minutes.
Kevin
Old 30th March 2011, 09:15 AM   #4
MOV's on are only a few dollars.
I used to install them in all of my power strips and I have had them for more than 15 years. jer
Old 30th March 2011, 12:07 PM   #5
Eric's Avatar
Thanks for the input, guys. I do have one that I installed on the main breaker box for the house, I think it cost me $50. When overloaded, it shorts and pops the main breaker to the entire house.
I was just thinking of adding something to my power box for the theater system that would provide an additional level of protection. As I read more, it looks like MOVs are the typical device used in this area. I came across a neat little MOV from Littlefuse that has an integrated thermal fuse and third leg that can be used as an indicator that the MOV has not gone bad. Its from their iTMOV product line.
My original thought was to try to duplicate what Panamax and other do: shut down the system when the voltage rises above 135v or drops below 85v. I haven't found any schematics that represent this circuit, though.
Eric
Old 30th March 2011, 12:55 PM   #6
I used to have 1000 watt ups from UPC that kept the compter,mixer,amps and tape machine running just In case of such a situation accurd while we were recording and it did many times.
It was funny listening to the playback of when the power went out as we were still recoring!
There are ones in that power range and bigger that have outputs that are a continuosly regulated line voltage with battery backup as well as there one that don't have backup protection
This also insures no noise from the power source. jer
Old 30th March 2011, 01:49 PM   #7
Eric's Avatar
Ha- I was thinking about this as well. I have two UPS devices, both have dead batteries and I've been too lazy to pull them apart and replace the batteries. I didn't spend the time to "exercise" the batteries on a regular basis, so they don't work anymore. Perhaps its time to dust them off...
Old 31st March 2011, 06:03 AM   #8
They are usualy 12v lead acid type or two 6v's in series.
I have always wondered if A car battery would work?
This would be a much cheaper replacement and it would give a very long backup down time. jer
Old 31st March 2011, 12:37 PM   #9
Eric's Avatar
Yes, the ones in my UPS are twin 6v sealed lead acid batteries that weigh a ton. A car battery would not work the same way. Car batteries are intended for short bursts of high current draw and cannot sustain a prolonged draw at any kind of "real" current. If you are thinking of going this route (which you certainly can) you should look for a "deep cycle" battery that has a very different physical construction than a car battery. The downside is that the price of deep cycle batteries is accordingly higher...
Old 31st March 2011, 06:59 PM   #10
Eric
That just doesn't sound correct.
Well, maybe in a thunder storm.
What does overloaded mean?
Kevin
DIY repair, a power surge, a mixing console, and me. mockd Everything Else 5 27th March 2010 06:56 PM
DIY advice matt J Digital Source 5 2nd January 2007 07:11 PM
noise and or rfi supression for dimmers for evaluation tests dannymansbach Power Supplies 3 8th July 2005 07:27 PM
DIY surge suppressor? cowanrg Everything Else 2 23rd June 2003 01:11 AM
Page generated in 0.11418 seconds (72.57% PHP - 27.43% MySQL) with 10 queries
