Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
RS232 - Does it require a termination?
Old 20th March 2011, 06:46 AM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default RS232 - Does it require a termination?
Hi.
I have a data logging system which takes several serial inputs.
We had a lightning strike nearby a couple of days ago and that's when my problem started !
It is only with one channel of data. As far as I can tell, the other 3 are fine.
It's a rather ancient system with a backplane, 386 one-board cpu card and a 4-channel serial card.
I have changed the card, cpu board and hard drive to no avail.
First problem. The card was receiving data at 19200baud - no problem. After the strike, it has refused, even with the changes above. It works at 9600baud. This I can live with.
Second problem. One channel (as above) occaisionally refuses to record the previous 10secs of data flagging an error. This occurs about once per hour , randomly.
The data cable feeding this port has a branch (daisy-chain). If I terminate this with a RS232 tester/indicator the error stops !!
Does RS232 require a termination to work correctly? I cannot find this out.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 20th March 2011, 11:57 PM   #2
DF96 is offline DF96  England
It is over 10 years since I last played with RS-232. It is a point-to-point system, so a branch is not supported although you obviously got away with it before the lightning strike. Maybe the load of the tester is suppressing some reflections? Or is it changing the grounding?
Old 21st March 2011, 12:07 AM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
A long time here as well! I last had RS232 on a Hawkwind tour to drive some custom lighting effects, (before DMX!), and the builder insisted on daisy chain linking, and provided some termination plugs, (one of which I threw at an Austrian traffic warden, but that's another story! ), and these were needed to prevent false triggering.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 21st March 2011, 01:23 AM   #4
Pano is offline Pano  United States
Pano's Avatar
I used to run very long RS-232 lines around basketball courts for the scoring and stats system used by the officials. Never used termination, never had a problem. Maybe the devices were already terminated?
I still use RS-232 to drive the DCX2496.
Take the Speaker Voltage Test!
Old 21st March 2011, 06:07 AM   #5
poynton's Avatar
Thanks for the replies, guys.
Yes, RS232 is vintage but so is the equipment I'm using ! 396SX with 387SX maths coprocessor, 1m ram and DOS 5. It's slow but it works. (The techs did try migrating the system to a more modern platform but it was not as reliable!)
Just to satisfy myself, yesterday I disconnected the RS232 tester. The errors returned ! After 4 hrs, I reconnected the thing and have not had one since.
So no more messing about, it stays connected. Only another 3 weeks of the project left ......
Andy
Old 21st March 2011, 07:52 AM   #6
davidsrsb is offline davidsrsb  Malaysia
RS-232 is not terminated. It is a high impedance load system.
It is not intended for cables longer than 50 feet (but is does work way beyond this)
Data levels are typically +/-10V
Has a 0V got disconnected?
RS232 - Does it require a termination?Hide this!Advertise here!
RS232 to I2S conversion kiranpreddy05 Solid State 17 9th September 2010 09:31 AM
Load termination cathode_ray Instruments and Amps 5 23rd August 2007 11:57 PM
Load termination ? cathode_ray Tubes / Valves 4 31st July 2007 01:12 AM
Copyright ©1999-2017 diyAudio
