| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Do magnets stick to mu-metal ?
Magnets stick to steel, but do not stick to stainless steel (confirmed that first-hand this morning). Just wonder about mu-metal. Anyone know ? .
Michael Gazzaniga - "The arts are not frosting but baking soda." |
#2 |
magnets saturate mu metal at much lower B value than iron so the "holding/lifting" force may feel unexpectedly low - since mu metal is often supplied in thin sheets too the force would be small
and until you degauss your mu metal its useless for low level mag shielding after playing with a magnet |
#3 |
frugal-phile(tm)
I have some mumetal downstairs somewhere. making an experiment a possibility.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
magnet's "holding/lifting" force can be looked at from an energy perspective
a magnet "engergies" a region of space with B*H/vol a high perm material lets the field complete thru a shorter distance, leaving less energy in the system so a thick piece of iron can mostly "short out" nearly 1/2 the external field of a magnet - the holding force can be calculated as the change in mag field energy for a small relative movment a thin iron sheet saturates, can't conduct all of the magnetic flux, so there is still external mag field in the air on the far side of a thin, saturated sheet and the force is much smaller since a small separation of magnet and saturated thin sheet doesn't change the external mag field much mu metal saturates at a fraction the level that iron/low carbon steel so the force from moving a magnet close to a thin sheet of mu metal is even lower |
#5 |
Thanks guys for helping me puzzle this out (will probably order some, but am curious about what to expect with this stuff). Google found someone else that indicated that it's less magnetic than steel (but maybe because it's normally so thin).
Let me rephrase the question, if it helps, to understand how magnetic we are talking about . . . Does mu-metal stick to a magnet ? .
#6 | |
There is no known material that blocks magnetic fields without itself being attracted to the magnetic force. Magnetic fields can only be redirected, not created or removed. To do this, high-permeability shielding alloys are used. The magnetic field lines are strongly attracted into the shielding material. There are many types of shielding materials. |
#7 | |
#8 | |
SALE! - Rare Ultraperm 80 Shielding Sheet-The Electronic Goldmine |
#9 |
Iron/low carbon steel is much cheaper so you can use lots, box source and "victim" circuits separately with air space
don't use mu metal near the xfmr: it will saturate, only useful after other measures have cut the mag field down - usually used to just box the most sensitive part of "victim" circuits |
#10 |
Banned
| Need to source Mu-metal cans | phrarod | Digital Line Level | 29 | 3rd September 2010 05:56 PM |
| Neodymium magnets vs Ferrite magnets | blueae1405 | Full Range | 56 | 17th November 2009 08:25 AM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| Attach driver magnets to metal frames? Yes, no? | talatnat | Multi-Way | 0 | 26th May 2006 02:34 PM |
| amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? | siu sin man tho | Digital Source | 0 | 17th March 2004 12:31 PM |
| Page generated in 0.12266 seconds (79.79% PHP - 20.21% MySQL) with 10 queries |
