| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I would like to build a remote volume control for my older (non home theatre)
receiver. The audio/vca/motorpot section is no problem for me, I just can't find info on the IR receiver/decoder section. There are IR receivers available at Radio Shack but info on how to interface and program them escapes me. Goals: 1. To be able to be controlled by an inexpensive universal remote using the "Audio" button on the remote. Ideally, it would mimic a known home theatre receiver so that I could just program the remote by holding the "Audio" button and entering a three digit code. 2. To power up in a sane mode. Volume at 10% or so, NOT 100% or mute. 3. LED bar graph for gain/attenuation indication. 4. To be an external unit connected to the receiver's eq/processor loop. No problem here. I have elex fabrication facilities. If I get it going, I'll post link to complete info. Thanks in advance for any info, Emory
no sig |
#2 |
Ask Weeder Technologies,
http://www.weedtech.com/ Terry Weeder has a simple solution, but I don't know if his project or products still selling. |
#3 |
hy Emory
look at Philips Semiconductor for SAA3009 or SAA3049 (RC5-Receiver) If you need a schematic for using the SAA with a motor poti, send me your email-address. best regards Kay
best regards Kay |
#4 | |||
[QUOTE]Originally posted by emorysmith
[B]I would like to build a remote volume control for my older (non home theatre) receiver. The audio/vca/motorpot section is no problem for me, I just can't find info on the IR receiver/decoder section. There are IR receivers available at Radio Shack but info on how to interface and program them escapes me.[/QOUTE] I just designed a remote control receiver some months ago - have a look here: http://stiftsbogtrykkeriet.dk/~mcs/Remote/index.html Quote:
I am also working on a remote controlled "passive preamp" as well as a board with relay or chip attenuators, but that's not complete yet... Best regards, Mikkel C. Simonsen |
#5 | ||||
#6 | |
But it only took me a couple of hours to make my own replacement chip using a microcontroller ;-) Best regards, Mikkel C. Simonsen |
#7 |
hello Mikkel
>Aren't those Philips chips obsolete? Can you still get them? This is correct, but I have four. >But it only took me a couple of hours to make my own >replacement chip using a microcontroller ;-) This is also correct, but can Emory do it? Best regards
best regards Kay |
#8 | |
#9 |
Here's some great info:
Pre-programmed PIC. Reads Sony RC. Has 4 or 8 momentary and toggle outputs. http://www.pics.com/~grieb/IR.htm I'm in progress of getting parts together. Using relay on a toggle output for mute. Using motorpot on momemtary outputs for volume. http://24.92.73.209/pix/irvolcont.pdf Might change daily. (As might the IP :-( ) Yes, the LM18200 H-Bridge is overkill but I have several ;^)
no sig |
#10 |
Why you don't make your own controller?
Bascom is free for 2kb (Basic-Compiler for AVR, use the AT90s2313)
best regards Kay |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 08:22 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.15288 seconds (74.63% PHP - 25.37% MySQL) with 10 queries |
