Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd March 2011, 05:21 PM   #1
BrianVG is offline BrianVG  Belgium
Post Room acoustics
Hi all,
I'm using a Yamaha HTT 6230 reciever with JBL E80's.
The photo shows my right speaker, but the two speakers are in the same position, they are surrounded by a wall and a closet. When I play my music/movies at a moderate level everything is fine, but when I turn it up it starts to get boomy. I was thinking to buy acoustic foam to place around the speakers(only helps for high and mids?) and some carpet in front of the speakers.
Does someone have any ideas that could improve the acoustics?
FET fanatic
Old 3rd March 2011, 05:30 PM   #2
GoranB is offline GoranB  Poland
GoranB's Avatar
Dont use the tone controls, dont increase bass, if your receiver have direct input switch use it, also buy a carpet, speakers should be far from rear walls. I cant open the picture you attached, but my suggestions in general should improve the bass.
Old 3rd March 2011, 05:35 PM   #3
Yes they should, but it's impossible to achieve that. Space is limited.
I'll fix the photo.
I'm thinking to buy this kind of carpet
FET fanatic
Old 3rd March 2011, 05:45 PM   #4
Does the speaker have a port at the back? If so, I suggest that unless you can move the speaker away from the wall, the port should, at least partially, be bunged up with a bit of foam to avoid boominess...
(Or that's what I've always understood)
Old 3rd March 2011, 05:46 PM   #5
GoranB's Avatar
[IMG]file:///C:/DOCUME%7E1/Goran/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Close that holl with sume sponge
Old 3rd March 2011, 05:48 PM   #6
Oops, just looked at the manual for your speaker, and the port is at the front. Ignore me...
Old 3rd March 2011, 05:51 PM   #7
GoranB's Avatar
Even the port is on the front side of speakers the bass will be boomy if you have the speakers close to rear and sides walls. I would close it.
Old 3rd March 2011, 05:55 PM   #8
GoranB's Avatar
Also try different speaker cables they should be short as possible.
Old 3rd March 2011, 05:57 PM   #9
GoranB's Avatar
Now i can see the photo, that closets ruins all
Old 3rd March 2011, 06:06 PM   #10
Speaker cable is DIY 1,5mm˛: 1,60m long , twisted and shielded. I'm not going to change that because I don't believe that any exotic/expensive cable can improve sound.
So the closet ruins all? I was thinking the same. That's why I want to place some acoustic foam against it
Question: is it worth it?
FET fanatic
changing room acoustics syntheticwave Everything Else 2 10th June 2008 09:29 AM
Improving room acoustics chrispenycate Everything Else 0 29th September 2006 10:03 AM
Room Acoustics systemerror909 Multi-Way 4 21st January 2006 01:42 PM
Sorting out room acoustics IanHarvey Multi-Way 76 11th April 2005 06:40 AM
The Power of Room Acoustics toenail Multi-Way 2 26th March 2003 01:55 PM
Page generated in 0.10298 seconds (82.05% PHP - 17.95% MySQL) with 11 queries
