Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Good quality cable for homemade XLR
Old 28th February 2011, 09:37 PM   #1
Romain123 is offline Romain123
Default Good quality cable for homemade XLR
Hi folks,
I am looking to put together a few XLR cables. This will be my first time. Anyone have recommendations regarding the kind/brand of cable I should by? Does Take Five audio have any cables you would recommend for this?
Muchos gracias,
A+
rc
Old 28th February 2011, 10:22 PM   #2
mickeymoose is offline mickeymoose  Canada
I really like the Canare L-4E6S quad-star cable. Great CMRR, good flexibility and ruggedness, nice "velvety" feel. Neutrics on each end, you can't beat it.
Disclaimer: I do not own stock (unfortunately) in either co. E
Old 28th February 2011, 10:37 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
The Star-Quad cables would be a good choice, but their high capacitance might cause difficulties in a few cases. In other cables look for symmetrical construction. Those with foil shields and a drain wire are a poor choice.
Kevin
Old 1st March 2011, 11:26 AM   #4
Great, thanks, I will probably try the Canare.
Old 1st March 2011, 12:36 PM   #5
Jim Leach is offline Jim Leach  United States
If the runs are only a few meters or less, you can't go wrong with these:
MOGAMI® - Professional Audio Cables
And the price is reasonable. Most music stors carry them, or can get them.
EDIT: The "Neglex" line is the way to go.
"When the world is running down,
you make the best of what's still around."
Old 1st March 2011, 01:13 PM   #6
Joschl is offline Joschl  Germany
Joschl's Avatar
I'm using 7m of this
SOMMER CABLE - Galileo 238 Plus 200-0271
imho a good one for the money
Old 8th April 2011, 05:14 PM   #7
cbdb is offline cbdb  Canada
Just read this and figured i should start with a question. These are mic cables not cables to interconnect 2 pieces of gear with xlr connectors, right? Because although they look the same they dont work the same.
Havent made a mic cable for a while but the Mogami used to be kinda the standard for higher end recording studios, and everybody else used the Canare (almost as good, a lot cheaper). And dont scrimp on the ends. This is the big choice. Unless you can afford the Neutrix , but there must some good competition these days? Some one used a cheaper alternative I dont know about?
This capacitance shoudnt be a problem for the low impedance mic inputs. And the quad construction is better for EM rejection. Yes foil shields bad, braided shield good. And remember to connect the shield at both ends for mic cables (usually only one end for interconect cables, but then you rethink the whole cable)
Old 11th April 2011, 03:56 PM   #8
noSmoking is offline noSmoking  United States
noSmoking's Avatar
go look at musician's friend all cable,flavors and prices ready made too!
Old 13th April 2011, 03:25 PM   #9
geraldfryjr is offline geraldfryjr  United States
I used over mile of cable from "West Penn" in my recording system and have never had any issues with it. jer
Old 14th April 2011, 10:31 AM   #10
PaleRider is offline PaleRider  Norway
PaleRider's Avatar
Want to do the ultimate IC?
Go to German ebay & order some TV-coax named Vivanco KX-710. Double configuration, only use center for signal, this goes for both XLR & RCA.
Good quality cable for homemade XLRHide this!Advertise here!
RCA to XLR cable, where to connect the sleeve? klitgt Parts 18 19th September 2017 05:48 PM
XLR / Balanced cable chipamp akunec Chip Amps 44 21st May 2010 07:35 PM
Re-terminating a XLR cable with RCA connectors fatwok Parts 9 14th February 2009 11:50 PM
XLR cable for unbalanced connection jarthel Everything Else 10 12th July 2007 12:06 PM
High quality XLR socket/connector? lovemov Solid State 6 19th December 2003 07:17 PM
Copyright ©1999-2017 diyAudio
