| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#61 |
The server resizes the images to fit. Your browser may resize also. Sometimes it takes a few seconds to happen, that's why you see a big image, then a small one. Unfortunately, even when resized to fit the screen, the file size can still be huge.
Schematics present a problem. If the image is clean, then even a big, detailed image can have a small file size in GIF or PNG format. But if it's a rough looking scan, the file size will jump thru the roof. Either way, it's best to attach it.
Take the Speaker Voltage Test! |
#62 | |
I usually attach a few pictures to show my approach, etc. For projects I'm chronicling and have many photos to share, I post a link to Photobucket. Why would that link disappear in time? Does Photobucket change the link somewhere along the line? I'm not aware of any links changing to my Photobucket site. Are you saying hi-res photos (> 1meg) should not be attached, but only use little 80k sized images? Last point... I don't like having to change my camera's resolution (it's a hassle) all the time just to post a couple of photos. That's why the few images I do ever upload are > 80k. As soon as I forget to change the resolution and try to upload a large file and get an error, I usually just give up and don't post anything. |
#63 |
Redjr.
Your post is full of errors. There's no limit to the number of pics you can attach to the Forum. There is a limit (I don't know how big) to how many pics can be attached to a single post. The pic size is limited as described in Manage attachments. Remote servers habitually lose data links, or shut down, or require registration or simply don't link. Hi res pics can be attached. Just compress them using efficient compression software to keep under the pic size limit. I use Irfanview. I don't need to change my camera's resolution. It downloads a full resolution pic of >2MB for each pic. After cropping and compressing to a hi res pic I often find 100k to 200k is very good quality on a 1920x1080 monitor. If I compress to lower resolution I can get good lo res pics to <50kB Use software that is easy to work with. Complicated software is no good to me, I can never remember where all the options are buried in all the submenus.
regards Andrew T. |
#64 | |
#65 |
Speakerholic
10 files max per post. All files around 125k
#66 |
Speakerholic
Screen shot.
#67 |
Thanks Cal. I thought it was somewhere around that number. I never embed my pictures in the body of the post anyway. I always attach them, but I've found you cannot do 6 or 7 at a time. Maybe mine were too large. I've also discovered that the Forum software does apply some level of compression too. It would be nice to know the exact raw size it allows before their compression takes over. Maybe those metrics are published somewhere.
#68 |
No.
the Forum produces/creates a Thumbnail/s that lets the reader decide if he needs to see the bigger picture. That's what makes it quick and convenient for the reader/s.
regards Andrew T. |
| Unable to attach files | goldyrathore | Forum Problems | 8 | 6th March 2010 09:16 PM |
| how to attach photos | g(f(e)) | Tubes / Valves | 2 | 9th March 2008 12:36 AM |
| Can't attach Photo's | c2cthomas | Forum Problems | 3 | 13th May 2007 12:29 PM |
| Anybody know how to attach heatsinks | 3-LockBox | Class D | 5 | 12th July 2006 07:28 PM |
| Page generated in 0.14601 seconds (44.68% PHP - 55.32% MySQL) with 11 queries |
