Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th July 2003, 05:40 PM   #1
Default Correct XLR connections?
I'm putting together my Aleph 5 and I'm wondering what the correct connections are for the XLR connector. The connector (as seen in the picture below) has a tab connected to the frame of the connector and pins 1,2, and 3. Traditionally, which pin does +, -, and G go to? For added clarity I've included the power supply diagram I'm using.
Dan
Click the image to open in full size. Click the image to open in full size.
Old 27th July 2003, 06:12 PM   #2
JOE DIRT®'s Avatar
pin 1=+
pin 2= -
pin 3= ground
tab= ground
Old 27th July 2003, 06:12 PM   #3
trwh is offline trwh  United Kingdom
trwh's Avatar
Hi Dan
In this pic, you can see that pin 2 is hot (+), pin 3 is cold (-), and pin 1 is ground.
Hope this helps,
Tim.
Old 27th July 2003, 06:14 PM   #4
trwh's Avatar
Oops, Joe posted while I was composing, and my pic didn't come out clearly. Visit this page for a better look:
http://www.rane.com/note110.html
Also, I notice that our advice isn't the same - with respect the Rane site will be correct.
See ya,
Tim.
Old 27th July 2003, 08:24 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Tim is quite right. That is the most commonly used connection format, and the industry standard for balanced connection.
c3g connections garbage Tubes / Valves 8 16th October 2010 09:51 AM
43% UL connections Hojvaelde Tubes / Valves 18 23rd June 2009 01:00 AM
BNC connections... Stormrider Parts 2 22nd June 2008 08:24 PM
no connections at all! Joel Tubes / Valves 0 31st January 2003 06:32 PM
Page generated in 0.08051 seconds (71.84% PHP - 28.16% MySQL) with 10 queries
