Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th July 2003, 12:14 PM   #1
Default Home Theater Fans: Does 5.1 Mean All Channels Are Integrated?
Having a discussion on the following thread:
passive filter for sub
Moi has a Sony DVP-S735D DVD Player, which is apparently both a DVD player and A/V preamp.
It has 5.1 channels, Mpeg and DTS decoder, whatever that means.
http://www.amazon.co.uk/exec/obidos/...362704-3990861
He has the Audio outputs from this to a variety of amps. His question: Is the subwoofer fully integrated with the satellites and center channel crossover-wise?
I would think that the 5.1 system would mean that there is an internal crossover which cuts the subwoofer in at the same frequency that the satellites are cut out, therefore making any external crossover unnecessary.
Is this the case? Is any unit that carries the "5.1" label set up so that you can just hook up the Audio outputs to appropriate amplifiers and forget about crossovers? I am looking for confirmation here.
Thanks.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 27th July 2003, 03:20 PM   #2
mrfeedback's Avatar
Default Read These Pdf's.
What is the LFE channel? might help you.
According to Dolby, the 0.1 channel channel is named LFE (low frequency effects) and runs 120Hz and down.
Dolby Technical Overview
Hope this helps,
Eric.
I believe not to believe in any fixed belief system.
Old 27th July 2003, 07:29 PM   #3
purplepeople's Avatar
keltic,
Quick answer: Yes, the channels are already properly filtered before the outputs.
Caveat: Only for units with 5.1-ch analog outputs. Anything with only 2-ch output has downmixed AC3 into matrix for ProLogic decoding.
For Sony, the XO for the sub is 120Hz.
How? I have a Sony DVP-NC650V 5-disc DVD/CD/SACD changer. It has 5.1 analog outputs and all I need are 6 channels of amplification.
:)ensen.
PS: I'll post this in Moi's thread too.
Those who claim to be making history are often the same ones repeating it.
Old 27th July 2003, 07:32 PM   #4
Ken L is offline Ken L  United States
Not looking at the manual or owning one,it is hard to say specifically with any certainty because there are variations in the chips and how units are setup.
However, my Nakamichi did cut in the LFE only when being fed a 5.1 single and when being fed a stereo signal you could not select LFE
HTH
Later
Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 28th July 2003, 03:45 PM   #5
I believe the various 5.1 standards specify the XO frequencies prior to mastering and a 2.0 mix is offered on most DVD software for those without the AC3 or DTS decoders.
Although not strictly needed because of the secondary software mix, my DVP-NC650V can also downmix the 5.1 into 4.1, 4.0, 2.1 and 2.0 if I set up the internal "speaker" menus. I'm guessing this is done with DSP. I find this feature handy as I'm currently running 4.0 into a 4-buss mixer and XO a sub post fader off the L/R mains. As you can see I will need a 6-channel pre to do this properly one day.
It also has a normal L/R output for use with a ProLogic receiver and that would be when one selects the 2.0 mix in the software.
I can't imagine that a player with 5.1 output wouldn't also downmix since most of them would have internal menus for "speaker" set-up.
:)ensen.
Old 28th July 2003, 04:10 PM   #6
tiroth is offline tiroth  United States
Bass management is generally implementation-specific. My processor has "large" and "small" settings for each set of speakers (front, center, rear) and routes bass differently depending on the selection. It does provide a sub output in all modes. (Technics SH AC-300)
Despite this you will still need some post filter if you have large main speakers. If your mains go down under 40Hz and the sub is crossed at 120Hz, you can get some serious boom. I think this will require playing with filters to determine what sounds best. There will probably be a tradeoff between cinema impact and musical fidelity...which is why I'm considering some selectable filters for my system. Anyone done this? How was the result?
Old 28th July 2003, 06:12 PM   #7
On my DVP, I can set Large/Small/None for any of the 5 satellites and Yes/No for the sub. If I select No Sub, then bass automatically gets diverted to the mains if the L/R mains are set to Large. I do not know what happens if I select No Sub and Small Mains.
I'm guessing that if I select Yes Sub, then normal AC3 takes over and <120Hz gets sent to the sub and >120Hz to the mains - but I am only guessing. Anybody know what AC3 and DTS specify in this case?
As for music, the manual suggest using the 2-ch output for best results. I don't normally use the sub for music, but on the weekend, I loaned the system out as a PA for the office picnic and just fed the full-range signal into the sub which, of course, was forced into using it's onboard LPF.
:)ensen.
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Using Car Sub in Home Theater jprac88 Subwoofers 5 1st February 2007 10:53 PM
Home Theater XOtothelight Solid State 10 11th November 2005 02:06 PM
Car amp in home theater? JWFokker Car Audio 4 29th April 2005 01:47 AM
Home Theater PC F/S vdi_nenna Swap Meet 0 23rd June 2003 01:07 PM
Page generated in 0.17837 seconds (53.12% PHP - 46.88% MySQL) with 10 queries
