| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
im looking to get a rotary tool, they seem pretty darn handy to have around for cutting, grinding, etc... which is the better one to get? im looking at the dewalt, craftsman, rotozip, or dremel?
i want variable speed of course, but all the fancy attachments dont really help me, i can get those later. i would LIKE to keep it under $100, but whatever, if i need to spend more to get a nicer one, thats fine too. but for the most part, the rotozip is the only one over $100. |
#2 |
If you plan using your rotary tool for light jobs and pcb drilling, Dremel is the way to go. Very cheap and they have a huge selection of accessories !
(some pictures here: http://www.diyaudio.com/forums/showt...273#post212273) If you plan to drill holes in HDF or MDF for your woofer or tweeter by example, you'd be better with a Dewalt as the motor is much more powerful than dremel. I hope this helps ! |
#3 |
does the dewalt offer me some accessory choices? could i still use dremel bits on the dewalt? i see that it has a universal chuck.
#4 |
As long as you have a universal chuck for your Dewalt, you'll be able to fit most important tools (such as drilling bits and router bits)
Drilling PCB will be a bit tougher but you seems to need a tool adapted for more serious job so Dewalt should be nice. Regards, |
#5 |
dremel makes pretty much all of the them...and I have a have a feeling Black and Decker owns them which is probably owned by the cooper group.....I personaly have the sears model and have used it for the past 8 years and it has served me well.....we bought a dremel brand for the company and it was used a few times and crapped out....funny that
DIRT® |
#6 |
Hi, I recommend a larger tool than the standard dremel pro, like the rotozip or dremel's look alike. I bought a dremel pro a while and although I've been happy with it I regret not buying the larger version. Of course you will need a flex shaft attachment to use the tool for working with fine parts. Rotozip, as the others, has a flex shaft option which allows the use of any of the dremel bits or any others meant for rotary tools, it also makes a great light duty router(I have a router attachment for my dremel but, for the lack of a better word, it sucks). I found that once I had a rotary tool it became indispensable, I'm sure you will be happy with whichever you decide to buy, but if possible don't skimp, my father once told me "only buy a tool once", following his advice always fared me well.
#7 |
Buy the bigger one. I have Dremel, but don't remember when I was using it last time. Most of my better tools are running on air anyway.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 |
sounds good guys. i think ill go with the dewalt, because the rotozips seem pretty pricey, and i doubt its all that much better than the dewalt. (from what i understand dewalt makes pretty nice stuff).
also, the routing stuff isnt a big deal, i have a craftsman router and router table... so i got that all covered. i do like the flexshaft idea, but i doubt i would use it much. ive got a really steady hand as it is. and my next purchase is a drill press, and i already have 2 drills. i would mainly use it for widening holes, those damn IEC holes, speaker baffles, etc... so, probably heavier duty stuff. does anyone see a huge advantage that the rotozip has over the dewalt for the money? |
#9 |
For pcb drilling get proxxon - its nearly pen sized and fairly light. After using it http://www.proxxon.com/en/28500.html, the famous Dremmel seems just big n heavy...
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots. |
#10 |
I recently purchased a ROTOZIP from Home Depot with accesories in a kit for $99.95. This baby cranks. It's like a Dremel on Steroids.
| The last tt alignment tool you'll ever need? | Conrad Hoffman | Analogue Source | 18 | 11th June 2009 06:47 PM |
| Need a tool! | Tenson | Multi-Way | 12 | 19th March 2007 08:36 PM |
| DIY Speaker tool | Jimmy DIY | Multi-Way | 4 | 18th December 2006 03:12 AM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 16th April 2004 11:33 PM |
| Demagnetising Tool/Tool Demagnetiser | mrfeedback | Everything Else | 30 | 4th October 2002 11:53 PM |
| Page generated in 0.13534 seconds (71.06% PHP - 28.94% MySQL) with 10 queries |
