diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Best cable configuration? (http://www.diyaudio.com/forums/everything-else/181648-cable-configuration.html)
Nisbeth 22nd January 2011 10:38 PM
If I want to build RCA-cables out of wire with two wires and a shield, should I then parallel the two inner wires (for a "coax" configuration) or use both one of the inner wires and the shield for ground (for a "shielded twisted-pair" configuration)? Assume that each of the inner wires are thick enough to carry the signal on their own.
/U.
pinkmouse 22nd January 2011 11:37 PM
Standard in pro-audio is to use the cores for signal and ground, and connect the shield at just one end.
Resources saved on this page: MySQL 18.75%
