| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
i cant seem to post any pics they are too big i know they need to be 100k but how do you guys get jpgs to be that small what program u using to convert it.
#2 |
JPEG is a compressed format and so it should not be a problem to keep pics below 100k in size. Width of your pic should not exceed 800 pixels, and then it will be difficult to generate a JPEG wich is larger
You should use medium JPEG compression (around level 5), and everything will be fine. Personally, I am using Photoshop; if you are looking for a free solution you might consider this, wich is a rather poweful tool: http://www.irfanview.com/ |
#3 |
#4 |
frugal-phile(tm)
I too use PhotoShop. If you do any sort of raster image editing but can't justify PhotoShops cost, PhotoShop has to be the cost/benefit leader (even better than most of the freeware). If you are on a Mac, Graphic Converter is an excellent piece of Shareware.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
I use ImageMagick. ImageMagick supports every known file format, works on nearly every platform, and costs nothing. I do:
Code:
$ convert -geometry 800 oldpicture newpicture.jpg |
| Post your pics | guitargully | Instruments and Amps | 30 | 2nd June 2010 06:41 PM |
| Post your pro amp pics here. | lt cdr data | Solid State | 6 | 17th October 2006 07:50 AM |
| Page generated in 0.08612 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
