diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Replacing Lamp Sockets To One With Higher Power Rating? (http://www.diyaudio.com/forums/everything-else/179176-replacing-lamp-sockets-one-higher-power-rating.html)
kelticwizard 15th December 2010 05:19 AM
1 Attachment(s)
Okay, this is not strictly an electronic problem, but I figured an electrical problem was close enough.
I would like very much to purchase the lamp table pictured below. It can also be seen here:
Medium Oak Side Table With Lamp Leick Furniture End Tables Accent Tables Furnishings
However, from reading other websites I find that the socket in the lamp only takes up to 60 watt bulbs. The person this is being given to will use this for reading, and a 150 watt lamp is preferred.
Is it any big deal to replace the socket in the lamp with one which will take a 150 watt bulb?
PS: "Some assembly required" for this unit, so the lamp stalk will not be attached to the table yet when purchased.
bob91343 15th December 2010 06:29 AM
The reason the lamp is limited to 60 Watts is not electrical. It is a heat issue. A 150 W bulb will radiate too much heat for the lamp and will damage it.
Get a different lamp, or concentrate the light with a reflector or magnifier.
Mooly 15th December 2010 06:32 AM
150 watts would generate far too much heat for the shade let alone the socket.
Can you use "low energy lamps", as a 150 watt equivalent is around 25watts or so.
kelticwizard 15th December 2010 03:59 PM
I thought that the screw-in fluorescents of 150 watt equivalent were too large to fit into the windowshade mounting apparatus, but I have been advised by someone who uses the bulbs that this is not the case.
Thank you both very much for your advice, I now feel free to order the unit and install a screw-in fluorescent when I assemble it. I felt very leery of exceeding the manufacturer's electrical ratings, now I know I don't have to. :)
Copyright 1999-2017 diyAudio
