Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th July 2003, 04:22 PM   #1
Bill Fitzpatrick's Avatar
Default HT vs Stereo - an issue not covered?
Frankly, I think home theater is the hype of the decade.
Here's why.
Presumably the criteria for audio reproduction with a stereo system is to recreate the sound of a live performance as accurately as possible.
It follows then that the criteria for home theater is to reproduce the experience enjoyed in the seat of a reasonably well equipped theater.
My home theater setup is as follows:
TV
VHS
Pre-amp
2 Satellites/2 Woofers bi-amped
Center channel is speaker in TV (L+R sum) and helpful because the included listening angle is about 80 degrees!
With the exception that I am missing some of the surround sound effects, which are of questionable value in the first place, I can't tell the difference between the presentation of the audio portion of my system and that of the theater's. In fact, in some respects my system is better.
With VHS, all you get is a stereo signal.
So, what exactly is gained with 5.1 channels of information from a DVD, processed by a complicated set of algorithms and shuttled through a multi-channel amplifier and five speakers?
I maintain that from conception, the advantage of home theater is solely for the profit of audio equipment manufactuers who needed to boost sagging sales - once the CD became firmly entrenched there was no encore in sight.
Home theater with it's equipment and attendant brohaha was a solution to a reproduction problem that didn't even exist.
I bought a DVD player a couple of years ago but never hooked it up so I'm going out on a limb here but I'll bet a dollar to a donut that a DVD will not sound as good as VHS on a regular stereo system - intentionally. I must try this someday.
To add insult to injury for the general population, the home theater systems that most people can work into their budget sound considerably worse than my system.
I'm not saying that the commercial offerings of home theater systems can be avoided. After all, we are being locked in. VHS is slowly disappearing from the shelves of stores and rental places so ultimately it's DVD or nothing.
I would be interested in your comments on this.
Old 17th July 2003, 05:00 PM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
I use stereo for music and movies. There are some arguments for HT 5.1 (or 5.2, whatever it takes ) if you have the entire package, including a large enough room to get the full effect of the Enterprise coming from behind and passing over your head.
To integrate a stereo system for music into a HT 5.1 system without compromising the stereo system sound would a bit difficult and very expensive.
I’ll stick with stereo.
Rodd Yamashita
Old 17th July 2003, 06:18 PM   #3
chris ma's Avatar
That's why I have my 2 channel stereo separate with the HT 5.1 channls. Unless you have all mono block power amps, excellent pre-processor that can decode AC3 and DTS yet performs as good as your 2 channel preamp.
How many of us actually sit on stage with the performers when they are playing anyway? It can be rather disturbing with people who used to soundstage and three D type of stereo imaging.
Having said that, Bill I think you should hook up the DVD and get some DTS DVDs and compare it with the VHS. The way AC3 and DTS having their discrete channel recording is pretty impressive. But lets try not get into the DD and DTS and or digital and analog contest here.
Chris
Old 17th July 2003, 06:44 PM   #4
Account Disabled
better yet, drop the Hell freezes over DVD and you will be convinced,
I think multi-channels do a much better job of helping you locate sound source and that usually translates into better imaging, especially for moving subjects.
Old 17th July 2003, 09:33 PM   #5
frugal-phile(tm)
planet10's Avatar
I have had a problem with real centre channels... switch it in an the image collapses front-to-back. Much better with a virtual centre. Surrounds are nice for movies, they can be somewhat distracting for music, but a lot of the software is still at the "ping-pong" stage of development.
My front mains are wired so that they are independent of the HT except that for movie watching they accept input from the HT processor.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th July 2003, 11:35 PM   #6
purplepeople's Avatar
If you already know about 5.1 standards, then skip to the section labelled "For the experienced..."
For movies, AC3 and DTS are now the standard for DVD because there is better separation of the surround channels vs. Prologic 5.1. And because the THX standards are so improved over past implementation, multi-channel SACD is now using roughly the same post DAC implementations and specifying 5 full range speakers instead of 2 full range and 3 satellite sizes. If we remember that SACD stereo is supposed to transduce 20-100Khz and at least 20-50Khz, that is a pretty stringent standard. (Yes, I believe the the standard is only 20-20KHz for 5.1 SACD, but cannot recall with certainty.)
Tomlinson Holman has been the guru of surround since Hafler in the 70's and Dolby in the 80's. His work AES related work has (so far) been the basis of most of the recent standards. You'll have to do some Googling, but it's all there.
http://www.tmhlabs.com/research/research.html
It should also be noted that 5.1 is completely unnecessary for listening to material recorded in stereo and can even destroy the presentation originally intended by the mixing engineer. With the right decoding, it is useful, but not needed for material that is stereo music with some surround encoding. There is a boatload of material on what matrix system is compatible with another so, sorry, yet more googling.
Finally, I think it is important to say that cheap 5.1 doesn't come close to even mid-fi stereo for soundstage, object placement and realism. It is fairly common for the quality of the analog stages to be the limiting factor in most consumer setups. And, they will continue to be until consumers get some discerning ears.
For the experienced,
nothing beats a high quality 5.1 decoder or processor. Most HT receivers at the US$750 level have decent processors, but don't have matching analog output until about the US$1500 price bracket. (IMO, as you can tell, it is not the processing, but the analog stages that need to be improved. Not A vs D but quality of both should match.)
Most pro-sumers make the mistake of getting a DVD player that has all sorts of features (DTS, 24/96, etc.) and then hooking it up to their HT receiver digitally. At that point, all those great specs are lost because the receiver is only 16/48 (or whatever) and has really noisy and distorted (pre)amps. They just bought this really expensive transport and they didn't know it. And, it probably doesn't have better jitter specs than the cheap DVD's. (Of course, the video is better, but that is not at issue here.)
This is why I bought the Sony NC-650V. It is an SACD/DVD/CD 5-disc changer. Since the analog output stages are shared, they have to be high enough quality for the SACD. They are not ES-series quality but way better than practically everything in the same price range up to about double the price. I not only get the wonderful analog outs, but 6-channels of analog output. With decent amplification and speakers, which is cheaper than any comparative HT set-up, I get HT at a mid-fi price. If I play a CD only the L/R mains give me sound. Too bad it is no longer in production. I think they still make the NC-700 series with 5.1 analog outputs.
Source: Sony NC-650V
L/R mains: Yorkville YSM1-p active studio monitors
L/R rear: Tannoy Proto-J studio monitors/Marantz 1530
Vol ctrl: Teac 2A 4-buss mixer
Finally, I think speaker placement is critical. In each SACD 5.1 case, there is usually a little diagram that shows the usual equilateral triangle with the addition of a circle. The ideal location of the rear surrounds is supposed to be at about 120deg relative to the centre channel with all speakers right on the circle for equal distance to your head. This ideal 5.1 set-up may not coincide with your ideal stereo set-up due to room reflections, bass boost, phase cancellations, etc. I believe this is the greatest problem when comparing an audiophile HT in both modes.
Dave: If you are having problems with your centre channel, it might be because you don't have the required delay for the surround channels. On any 2.0 matrix decoded to 5.1, there must be a delay of about 15ms total for rear channels. Without it, the brain is not fooled into thinking that the surround channels are behind. If the stage collapses relative to the LR mains, then you may require a digital delay (1 ms / foot) as a result of the distance from listener to speaker. I find that DVD requires a centre to locate dialogue properly at the screen. Even with my virtual centre there is a lag of about .25ms between the mouth movement and sound and I cannot compensate with my 1ms delay resolution.
Bill: In a nutshell, the advantage of 5.1 discrete over 2.0 matrix is the channel separation. And this is assuming that the quality of the recordings are the same, yielding the same low noise, and frequency range.
:)ensen.
PS: I try to be helpful and for me it is unhelpful to be incomplete. Thus, I tend to be pretty verbose so my apologies for any annoyances.
Those who claim to be making history are often the same ones repeating it.
Old 18th July 2003, 01:17 AM   #7
frugal-phile(tm)
planet10's Avatar
I have no probelm with the surrounds... even using just the front 3 speakers the front-to-back depth collapses with CC in. I don't have any problems with the virtual centre channel... it works really well.
dave
Old 18th July 2003, 01:53 AM   #8
Dave,
Does the CC have a LPF at about 7Khz? If not, higher freq which are highly directional all get heard down the middle, so it might really flatten the image.
I think that is also my problem. Since my DVD is full freq analog output, I think I need to put in the LPF in order to put in the CC.
:)ensen.
Old 18th July 2003, 01:58 AM   #9
purplepeople:
You seem to know what you are talking about but I think you are missing my point.
If I, and everyone else, can get 98% of what the THX certified theater presents to the audience with a relatively modest VHS/stereo home system then what's the point? Note that the comparison I make with my home system is to the REAL DEAL, not a $5000+ home theater system.
The missing 2% are really just localization effects artificially created and implanted to wow the ever gullible consumer into parting with their hard earned cash. They appear in relatively few films and fail to have the importance of other more significant factors in the reproduction chain.
I stand my position, "they" are just trying to sock it to us.
Unfortunately they are going to succeed. They just got $1200 bucks from some friends of mine. What did my friends get? Well, the BEST part was a single 8" woofer! Imagine that, a whole 8".
Old 18th July 2003, 02:59 AM   #10
frugal-phile(tm)
planet10's Avatar
There is no question there is a lot of that involved, but given that they will continue to make inroads into the marketplace people will try to squeeze what they can out of it.
dave
Epoxy covered crossover?? Ryder Multi-Way 10 24th August 2010 12:06 AM
cloth covered wire graeme uk Parts 11 30th May 2006 05:56 AM
Most covered song? infinia Music 1 5th April 2006 02:12 AM
Electrolytic cap question (not quite covered elsewhere) Puggie Parts 5 15th March 2006 03:23 PM
Material Covered Baffles? Super Multi-Way 5 4th August 2001 07:10 PM
Page generated in 0.16774 seconds (69.72% PHP - 30.28% MySQL) with 10 queries
