Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th July 2003, 03:17 PM   #1
sobazz is offline sobazz  Denmark
sobazz's Avatar
Default Passive preamp - best solution?
I stumbled across a one year old post about a passive preamp. It used a somewhat different approach to volume attenuation than those normally used. Instead of relying on the potentiometer a resistor was used in series and the pot's only function was to shunt a part of the signal to ground.
The thread is here
For the preamp I plan to use a spare ALPS RK40 10K. But would I benefit anything from using the above solution? If yes, what value should the resistor have (it's only a 10k pot)?
What are the different connections on the pot? There are four pairs of connections, the first 3 are numbered from 1 to 3.
Old 17th July 2003, 03:37 PM   #2
I'll leave it to the platinum eared to argue which sounds better, but part of his reasoning for doing it that way was due to the fact that he had a 100k pot. In a passive preamp you have to maintain a high enough impedance to not overload your source, but low enough to retain frequency response to the amp. 100k is too high. Your 10k should be just about right, if used in the traditional manner.
Old 17th July 2003, 03:43 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Passive preamp - best solution?
The value of a series resistor will greatly depend on your setup, gain of the amp, input resistance, speakers efficiency, even the type of Alps pot. I would suggest using a trimpot (variable resistor) initally and trying to find the best resitance range in this way. A 10k or 5k timmer should be a good value for a start.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th July 2003, 05:12 PM   #4
sobazz's Avatar
Thank you both. I think I'll wire the Rk40 in the traditional way, then. I don't feel like experimenting so much at the moment.
What are the fourth set of pins on the pot for? I read somewhere that the pot was a fake ALPS if the stícker on the back was not glossy but more like a photo copy. This is hopefully true. To me it sounds far out. What do you guys say? How can you recognize a fake ALPS RK40? I bought mine from LCAudio a couple of month ago.
Old 17th July 2003, 08:39 PM   #5
sobazz's Avatar
This should of course have been hopefully not true. It seems to me, that I cannot edit my post. I don't know why.
[edit]: Time limit, obviously.
F1 and a passive preamp? roscoeiii Pass Labs 10 10th May 2009 12:55 AM
My passive preamp?? jovan Solid State 1 27th February 2006 07:13 PM
passive preamp digi01 Chip Amps 4 8th February 2005 05:37 PM
passive preamp mjh77 Analogue Source 4 14th August 2004 10:06 PM
Passive preamp Flemming J P Everything Else 7 5th November 2001 09:40 AM
Page generated in 0.10300 seconds (71.86% PHP - 28.14% MySQL) with 10 queries
