Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th July 2003, 04:08 PM   #1
chris ma's Avatar
Default Pros/Cons Remote Power Supply
Hello Folks,
I would like to see more options when building a remote PSU for power amp.
The amp that I am building does not have room for all PSU components. So I would like to know more pros and cons for different configuarations;
My amp have room for the voltage regulators and may be the bridge recitifier but not the filter caps banks and the transformer.
Option
A/ -- Build entire separate PSU connect to amp via 3 foot long DC power cord 2sets, one for poistive and one for negative.
B/ -- Build PSU with only transformer, bridge rectifier, filtering caps then connect to amp where the voltage regulators can be located within the amp chassis closer to the power transistors.
Chris
Old 16th July 2003, 04:21 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
In my oppinion the best solution is your own suggestion B/
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 16th July 2003, 04:40 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
I would say skip the idea and build the PSU together with amp. It ads nothing to have long wires, infact I think this is a disadvantage. I can see a advantage for pre amps and MC preamp in particular.
For power amps it's common knowledge for striving to compactness, short wires and low resistance and inductance. It's also better from a RFI perspective, smaller antenna.
/Per-Anders (my first name) or P-A as my friends call me
Old 16th July 2003, 05:24 PM   #4
tiroth is offline tiroth  United States
I think split PSU has merits: box 1 with xform, bridges, moderate capacitance; box 2 with main caps and active circuitry. This provides much greater isolation from mains noise and transformer EMI than is generally possible in all but the best layouts. It is a lot of effort to implement though.
Old 16th July 2003, 05:39 PM   #5
Jan Dupont's Avatar
Peranders:
You may be right, but this is not the question here.
tiroth don't have space for the PSU in the amp cabinet
Old 16th July 2003, 06:23 PM   #6
slowmotion's Avatar
Hi chris ma,
If you want to go all the way
( or even half way there )
your suggestion B/ makes more sense to me,
I would hardwire the powersupply and the amp together,tho
cheers
Jan
Old 16th July 2003, 06:43 PM   #7
moamps is offline moamps  Croatia
Default Re: Pros/Cons Remote Power Supply
What's maximum DC current thru cord (amp power)?
"voltage regulators" are for power amp or for low level circuitry?
Do you think about separate power supply for each amp?
3 foot?...... Long distance.
Old 16th July 2003, 06:58 PM   #8
chris ma's Avatar
I am using two of those group buy heatsinks which is 11"X11"X2.75" each.
For each channel there are two heatsinks stacking on top so the amp is standing 22" high already. It is kind of like a large plate amp ready for future(may be) speaker project. The PSU will be regulated between 20 to 28 V and bias will be between 3.5A to 4A. Transfomer is 22-0-22 400VA
It is going to be mono block with it's own PSU.
The plate amps although it seems big but it is rather thin so there is no room for the PSU, just the amp is measured at 11"(w) X 22"(H) X 8"(D) the depth part includes the fins of those heatsink.
Chris
Old 16th July 2003, 07:08 PM   #9
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I would do this. Buy some nice Ofc Cable and make nice Power cables to the power amp from the psu.
make the Psu contain the Transformer Caps and regulators and bridge rectifiers. Use some nice Silver connector....
You that is what im doing for my small blue amps.
Old 16th July 2003, 07:32 PM   #10
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I would do this. You say you use 2 of those heat sinks per amp and it makes them 22" tall. Why not use heat sinks on both sides for lower height?
3 feet of power cord from supplies to the amp will definitely introduce the sonic signature of the cable to the sound. Also, buildinf separate PS is like building two amps instead of one. IMO, the drawbacks involved with separate PS are bigger than possible gains.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Pros/Cons on Split supply vs. Virtual Ground Archwn Solid State 22 13th July 2008 10:34 AM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 12:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 02:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
Page generated in 0.11989 seconds (78.11% PHP - 21.89% MySQL) with 11 queries
