Connectors
Any suggestions as to what and where to get for DC power entry receptacles and plugs for connecting the amp and PSU? I would like to use 3 connectors ideally.
I do not want to use normal AC plugs and receptacles just in case someone may make the mistake to plug the amp using the A/C line from the wall
I need high rated DC amps as well, any suggestions are welcome.
Thanks,
Chris
Thanks,
Chris
Re: Connectors
Speakon 8pole
http://www.neutrikusa.com/products/speakon/
chris ma said:Any suggestions as to what and where to get for DC power entry receptacles and plugs for connecting the amp and PSU? I would like to use 3 connectors ideally.
Speakon 8pole
