Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Why does the new stuff not last???
Old 5th December 2010, 12:45 AM   #21
Enzo is offline Enzo  United States
10 month old Chevy water pumps would not be planned obsolescence. I rather doubt general Motors designed those parts to wear out long before the warranty on them expired. Sorry about your family experience, but how many hundred thousand GM vehicles did NOT lose a water pump in that same period?
Old 5th December 2010, 02:47 AM   #22
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I was at a high end audio dealer here in NJ -- they had a tres cher tube preamp on display -- the electrolytics were bulging already! Can you imagine the reaction when some periodontist has his preamp blow up on him.
A friend in the SMPS biz says qualifying electrolytics is a disaster these days, made worse by the recession (as production is consolidated, consistency evaporates).
But to be fair, my Phillips electric toothbrush has worked without fail.
Old 5th December 2010, 04:12 AM   #23
gaetan8888 is offline gaetan8888  Canada
Hello
My RCA XL100 televison work since 1985 and it still working good, but as soon I've buy it I did made to the case a better aeration to reduce heat inside.
I have a JVC top loading vhs video recorder made in the 70's and it still work good, the only parts I've need to changed was the belts.
Most of the time I buy electronics gears I check the heat management and aeration and the power supply.
Most of the time I've ad to fix some electronics was because of too much heat inside, so many parts did overheat a bit and they fail after few years.
The worse was few cheap DVD players that I've fix, they ad some IC's and transistors who was heating like furnaces.
But there is also those electronics with cheap switching power supply, they have a so high HF noise that the capacitors are going dry or did burst because they was not real low ESR capacitors.
I try to keep my old electronics or buy used good quality ones, they are better made and easyer to fix.
Bye
Gaetan
Why does the new stuff not last???Hide this!Advertise here!
Cabinet dampening - to stuff or not to stuff? ViolenceOnTheRadio Multi-Way 65 26th September 2010 12:23 AM
Does any of this stuff do anything? CoolbeaN Everything Else 20 11th April 2010 03:15 AM
More stuff, again! Colescuttle Swap Meet 8 26th December 2006 06:05 PM
More stuff! Colescuttle Swap Meet 3 2nd November 2006 03:44 AM
spring cleaning FREE STUFF just pay shipping plus wtb/wtt ibook stuff relientk4life06 Swap Meet 3 24th May 2006 03:32 AM
Copyright ©1999-2017 diyAudio
