Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th July 2003, 01:23 PM   #1
moi is offline moi  Reunion
Question ps2 power supply
hi
does anyone know the output on the four pins on the ps2 power supply
thanx
bye
Old 15th July 2003, 02:48 PM   #2
diyAudio Senior Member
fdegrove's Avatar
1 Mouse-Data Mouse data packets or keyboard scan codes
are sent from the mouse or keyboard to the
computer on this single wire serially.
2 -- Not Connected (Reserved)
3 GND Ground for voltage
4 VCC +5 voltage (max. 500mAmp)
5 Mouse-Clock This signal is sent from the mouse or keyboard
to synchronize the data signal.
6 -- Not Connected (Reserved)
A pic of the male connector:
Frank
Old 15th July 2003, 03:05 PM   #3
analog_sa's Avatar
Frank
I have a suspicion this is not the same ps2
Old 15th July 2003, 03:18 PM   #4
fdegrove's Avatar
PlayStation 2 perhaps?
Unfortunately, if I guessed right, I haven't got a clue.
Sorry,
Frank
Old 16th July 2003, 08:09 AM   #5
hi
thanx for your answer
but its a ps2
only four pins
help meeeeee!!!!
Old 16th July 2003, 08:49 AM   #6
fdegrove's Avatar
but its a ps2
Yes, but what is it for?
Assuming once again it's for a mouse or keyboard you'll notice that on the 6 pin standard 2 pins are reserved wich allows the use of a Y- connector on some laptops to use a keyboard and mouse simultaneously using only one port.
So, if we ommit those two unused connectors you'd have:
From left to right when viewed from the top:
1. Data send.
2. Ground.
3. 5Vcc @ 500mA.
4. Clock and datasync.
Hope this helps,
Frank
Old 16th July 2003, 08:58 AM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
As far as I know the 4 pin mini-din is used for s-video.
PS2 mouse mini-din's have 6 pins.
The pinout of the 4 pin mini-din is:
1: Ground Y
2: Ground C
3: Y (Luminance)
4: C (Crominance)
The picture is taken from the solder side of the (male) connector.
Hope this helps.
If not, tell us some more about the connector (picture) or what you plan to do with it.
Greetings
/Hugo
Old 16th July 2003, 09:21 AM   #8
fdegrove's Avatar
Hi Hugo,
The connector is called a 6-pin mini-DIN, but some mice and keyboards are made with the (male) connector having only four pins
(i.e., with the unconnected pin 2 and pin 6 missing).
Your guess is as good as a mine though,
Frank
Old 16th July 2003, 10:18 AM   #9
moamps is offline moamps  Croatia
This one?
(IMHO, voltages are +5,+12, maybe -12)
Old 16th July 2003, 10:22 AM   #10
yes moamps
it's this connector
do you know the output power?
bye
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.10079 seconds (76.45% PHP - 23.55% MySQL) with 11 queries
