Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th July 2003, 12:23 AM   #1
Default Any Reason I Should Not Get WM61B Mic With The Pins Instead of WM60A ?
Checked out the microphone recommendations at Sigfried Linkwitz's site. http://www.linkwitzlab.com/sys_test.htm#Mic
He recommends the WM60AY and to modify it. I have no plans to modify just for simple speaker testing, which is what I plan to do with this.
He also mentions the WM61. The WM61B comes with pins to make soldering easy.
Both the WM 60 series and the WM 61 series appear to have similar flat frequency response.
My question is: Can there possbily be anything wrong with ordering the WM61B with the pins instead of the WM60A which is Linkwitz's first choice? It doesn't seem possible, but you never know. Seems to me the pins will make the soldering of the leads safer.
I would appreciate any ideas on this.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 15th July 2003, 01:00 AM   #2
SY's Avatar
I haven't used the '61, but soldering to the '60 was a piece of cake. And so was the mod. They're cheap enough to order a dozen of each and see which you like better.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th July 2003, 03:54 AM   #3
Okay, maybe I put the cart before the horse. Is the modification really worth doing? Because Linkwitz was talking about "distortion at moderate levels" without the modification, but then mentions such things as functioning well at 134 dB instead of 128 dB as being important. 128 dB is an 88 dB @ 1M/1Watt speaker driven by 10,000 Watts! It makes me wonder what Linkwitz considers "moderate levels".
Heck, if the modification is that easy, I'll just go "by the book" and do it Linkwitz's way. I'll order the WM60As.
Thanks for the input.
-Anonymous
A reason NOT to DIY.. ScottG Multi-Way 114 8th June 2008 02:20 AM
Any reason not to consider this? BHTX Multi-Way 9 2nd August 2007 08:21 AM
Any reason to add CDom? TomasF Solid State 2 11th May 2007 02:55 PM
A(nother) reason NOT to DIY AJinFLA Multi-Way 142 13th March 2007 03:04 AM
Any reason? MaXiZ Solid State 10 11th April 2005 09:06 PM
Page generated in 0.08699 seconds (63.99% PHP - 36.01% MySQL) with 10 queries
