Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Math Help
Math Help
Old 1st November 2010, 02:04 AM   #11
wdcw is offline wdcw  Australia
No worries, can I still just sum the two currents together seeing that the circuit is Inductive & Capacitive.
Cheers
Old 1st November 2010, 02:16 AM   #12
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
When you sum the inductor current with the capacitor's, remember to use vectors as their phases won't match LTSpice will do this for you though - just mouse over the voltage source and a current symbol will appear - click to graph the overall current from that source.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 1st November 2010, 02:37 AM   #13
abraxalito
I need to find the total current through the Capacitor when a 1050Hz signal is injected into a 230V signal.
So I am not sure a phasor diagram is going to find that, is it?
I have no value for L so I am not sure what IL or XL is.
Basically two voltages with different frequencies when mixed, do there currents add together?
Cheers
Old 1st November 2010, 02:48 AM   #14
abraxalito's Avatar
You have the C value, that's 4.9uF. Given that the question isn't asking about current into the inductive part (which means both phases are staying at 90), you can add together the current at 50Hz and that at 1050Hz. I haven't tried two different frequency sources in LTSpice myself, don't know if that works.
A phasor diagram when there's only currents in the same phase seems a bit overkill To answer your final question - its 'yes' when the currents are in phase and the load is a linear one (like a capacitor as you've got here).
Old 1st November 2010, 02:56 AM   #15
Yes, I see.
Thanks for your time abraxalito, it's greatly appreciated.
Thanks Again
Cheers
Old 1st November 2010, 03:02 AM   #16
abraxalito's Avatar
You're welcome, its blown a cobweb or two out of my rusty brain in the area of phasors...
Math HelpHide this!Advertise here!
Can't do the math! poorstudent Full Range 3 22nd November 2005 06:37 AM
Need some Math Help... ctardi The Lounge 3 21st June 2005 05:11 PM
math help needed hitsware Full Range 1 29th November 2004 03:29 AM
