Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th September 2010, 09:12 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Good point Kevin!
Anyhow, it's probably not a parabolic mic. Just a parabolic neighbor.
Old 18th September 2010, 09:29 PM   #12
Sounds like a job for a pile of bass shakers (find the studs), some 3" drywall screws, and infrasonic signal generator. Play around with it until you can get stuff to rattle on his side of the building. Whenever he gives you the "signal" you can return the favor. If the floor joists run across both rooms you can put some on there too. Or put a surface mic on the wall and send the output through a cheap delay/reverb unit to the power amp and turn up the gain just under the point of feedback. Just for fun, let it actually feed back once in a while. You could even run a line in from the bathroom. See how he appreciates that.
Old 18th September 2010, 10:45 PM   #13
Ok, thanks for the answers.
Maybe it depends on the actual implementation, shape of the deflector and type of (directional) microphone and amp.
the most probable alternative imo, is, he found a hole in the wall or made one and put a simple electret microphone with a wire just before the wallpaper. A cheap amp would suffice then. But a parabolic mic would be easiest because it leaves no traces plus one might get directional information (?).
White noise generator is a good idea but it will go on my nerves. I would prefer sound proofing but then again it would be useful to know what type of microphone is used because it's expensive...Until then: Hip-Hop
ps authorities won't believe you if you have no proof. They will think you're insane then which can be even further exploited by harassing neighbors. The only solutions in such a case are, if you think about it, defense (ie sound proof or moving away) or to take equal measures, that's the creepy thing.
Of course eavesdropping is a huge waste of time for everyone involved. I also suppose the person who does it gets an irrational feeling of superiority over time and can't stop it, it could be like a drug.
Old 19th September 2010, 07:59 AM   #14
dfidler is offline dfidler  United Kingdom
dfidler's Avatar
How to Protect Your Home From Listening Devices | eHow.com
Old 27th September 2010, 11:33 PM   #15
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
Originally Posted by trecker4 View Post
My neighbour is able to to hear very quiet sounds (like breathing) through a drywall between us.
(if you don't have a drywall, can you hear through doors?)
i lived in this building for a while (the larger one) -
a stout building,
all concrete, and steel.
it's truly amazing what can be heard,
especially at night.
sometimes i'd lay in the bathtub, water covering my ears.
and just listen.
refrigerators turning on, sound much like the 8-track,
in those soundesign receivers.
at night -
Old 28th September 2010, 12:05 AM   #16
Pano's Avatar
Jeez Tom, I didn't know you were that old! Did you park your Flivver out front?
Old 28th September 2010, 02:21 PM   #17
jneutron's Avatar
Yes, a parabolic mike will indeed work through a thin wall.
A parabolic reflector is designed to take a planar wavefront and reflect it into a focal point with time coherence. If a wall is vibrating as a result of sound energy, wherever it is vibrating in a planar fashion, the reflector will work correctly.
What will be lost is the directivity information if the wall acts like a piston source. In general, it will not be possible to discern the origion point of the source on the other side of the wall. But the parabola will need to be pointed directly at the wall, as any angle will destroy the pickup ability, with hf being lost first as a result of wavelength issues.
Cheers, John
Old 28th September 2010, 08:20 PM   #18
As others have previously noted, there are simple and effective ways to end your problem. My suggestion involves the early hours of the morning and a couple of packs of black cat fire crackers. If you really want to be creative, you can use a metal trash bin as the blast protection device and a sound "enhancer"..
Old 14th June 2011, 10:15 PM   #19
You can get a pretty cheap contact mic with built in amplifications, like the device at Listen Through Walls Device. I have one - works great on brick and drywall.
Old 15th June 2011, 11:23 AM   #20
DF96 is offline DF96  England
Would a sufficiently thin wall act more like a planar array of sources, excited by the incoming wavefront, rather than a piston? There would be the problem of reflection, and some phase shift at the edges becuase they would be less free to move, but I would expect a parabolic system to work reasonably well. You might even be able to achieve partial cancellation of reflections by using another mike and a time delay.
You could check for a mike in the wall by using a metal detector, such as those used by electricians to stop them drilling through wires.
Just one question: you are the recipient of this unwanted attention, and not the perpetrator seeking better technology?
Parabolic speaker... need to build one... dwalls32 Multi-Way 1 9th March 2005 01:51 AM
making curved walls thin paulspencer Subwoofers 2 10th December 2004 06:59 AM
Parabolic port????????????? digitalaudio Multi-Way 4 7th August 2003 01:50 PM
Parabolic Microphone Reflector mrfeedback Everything Else 8 24th October 2002 03:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
