| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
What's the best way to deal with this stuff after etching a PCB? I'm about to etch 3 boards and i have realized i've no idea what to do with the chemical later, other than throwing it in the garden...
#2 |
Banned
better not in the garden...Someone may want to grow something to eat there some day. Here they collect stuff like that.
i donīt think its much problem with the FeCl, but with the Cu. I think your FeCl will be about pH2. I would try to make it pH7 before getting rid of it. So the metals and salt will fell out and the liquid is essentially water. Mix it with NaOH or something with a pH > 7 like CaOH or cement (be carefull) |
#3 |
Something that can be found in the kitchen?
#4 |
Banned
****, i donīt know what is found in a kitchen with high pH. everything will be more expensive than cement.
#5 |
Baking soda
#6 |
http://www.inchem.com.ph/fecl3.htm
The page above discusses the uses of FeCL3 It is actually used as a water treatment agent. It shouldn't harm anything to pour it down the drain, as long as it is diluted (a lot). You don't want to etch your pipes Using baking soda will make CO2 - bubbles and foam - ever mix baking soda and vinegar? NaOH - drain cleaner (small white pellets) sometimes has small bits of metal in it. Reactions like this make large amounts of heat in high concentrations, and could be a splashing chemical burn hazard. l'd think the safest thing would be to dilute it a lot (100's:1) and pour it down the drain....but I've never tried it.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#7 |
Banned
the bad thing isnīt the Fe, its the Cu. It is very toxic as ion. So i think its the better idea to let it fall out in neutral solution and put the liquid and the solid componet separately away.
#8 |
water dilution is the best but I would not pour it down the drain as most plumbing is abs pipe....I have a 5 gallon pail and take my chemicals to the landfill site where they dispose of it
#9 |
i found that it worked wonders on my neighbours roses
his dog fouled my lawn his roses croaked
#10 |
That's what i was thinking... i'll just pour all the used stuff togheter, dilute it a lot and just toss it away somewhere far from my house
| Disposing of Old Transformers? | Tom D | Everything Else | 4 | 13th July 2003 03:36 PM |
| Page generated in 0.08693 seconds (78.72% PHP - 21.28% MySQL) with 10 queries |
