Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th July 2003, 07:28 AM   #1
JDeV is offline JDeV  South Africa
Default Voltage level switch
I eventually got hold of a small 500VA variac and is bussy to build a bench PSU. I will use the variac as priamary to a 45-0-45 1000VA toroidal. This combo will give me up to + and - 60 Vdc @ 8 amp. I got 14 x 10,000uF , 40 v caps and 2 x 15,000uF 63 v caps.
What I want to do , is to keep the 40v caps in circuit up to about 34v and then switch them out and only use the 63v caps further on.
Will the following circuit do this job, or is there a better/easier way to do it.
Thanx for all help.
"Be carefull who's advice you buy, but be patient with those who supply it."
From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen)
Old 4th July 2003, 07:39 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Humm... Should be good to 20 amps at full voltage.. connect some of the 40V caps in series and switch out the variac instead
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 4th July 2003, 09:18 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
In general when you have comparator functions you should also have hystereses so you won't get any "nervous" switching.
Just place a resistor from output to + input.
Your reference voltage should also be connected to the supply voltage not the "input" voltage. Otherwise you can get undefined states.
/Per-Anders (my first name) or P-A as my friends call me
Old 4th July 2003, 09:42 AM   #4
Jennice is offline Jennice  Denmark
With this many 10.00uF's you better be sure to ALWAYS start the variac from zero. Otherwise you rectifier bridges will not last long.
Also, I would use the 63V caps at all times.
If you really feel a need to use all those caps, I would (like someone else suggested) connect the 40V caps in series (and add a low-current voltage devider with resistors to ensure equal voltage sharing over the caps).
Each series connection will give 5000 uF, 80V, and two such sets will bring back the 10000 uF at 80V. This uses 4 caps, but as I recall you have a lot of them at hand.
Jens
Old 4th July 2003, 09:57 AM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
May I also respectfully remark that the limiting factor would be the variac, not the toroid, so with a 500W variac you're back to +/- 60V at 4 amps (about).
Jan Didden
Old 4th July 2003, 10:06 AM   #6
Thanx for all advice. I am taking note of all suggestions Surely don't want to fry my precious little variac.
Need Combo line/speaker level switch for sub mgkman Parts 4 17th November 2007 06:41 AM
remote controlled line level switch brainsalad Solid State 1 18th November 2006 02:34 PM
Line level muting switch pinkmouse Solid State 0 30th October 2004 10:33 AM
Three Way Attentunating Switch on -10db line level Parker_SMC Solid State 1 19th October 2004 09:02 PM
Line Level, Balanced Voltage Level... dkemppai Solid State 3 10th December 2002 11:04 PM
Page generated in 0.08673 seconds (73.24% PHP - 26.76% MySQL) with 11 queries
