Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Bybee Quantum Purifier Measurement and Analysis
Closed Thread
Old 6th September 2010, 04:37 PM   #451
john curl is offline john curl  United States
john curl's Avatar
My Bybee devices were given to me by Jack Bybee several years ago and they were soldered into a Blowtorch preamp. However, I removed them before shipping the Blowtorch preamp overseas, as I did not know whether they were allowed export at the time. That is why I have possession of 4 identical looking units. Since they were soldered in, my ends are somewhat shorter than maximum and solder coated.
In trying to find out what the wire is composed of, I scraped several wire ends with a scalpel made of magnetizable stainless steel over a strong rare earth magnet that I use for such testing, hoping to catch any magnetic particles with the magnet. I found that the exterior surface did not have much, if anything magnetic that would stick to the rare earth magnet. However as I scraped deeper, some particles started to cling to the magnet. At this depth, the color went from white to a copper color. I could take a picture of this, and I probably will just to have proof, but at this time, my computer can't even print, and I doubt that it can scan, as the main drive crashed 1 week ago, and I am now trying to fix it. I stand by what I am seeing, however.
Personally, I don't care to argue with SY about this. Perhaps, since he has a couple of units and knows chemistry, he can better determine the constitution of the leads. I will simply ask Jack Bybee when I can next reach him, as I am only making an educated guess from having the devices, running a magnet across the devices, noting the absence of magnetic material in the device body, itself, and Googling military grade wiring that fits the description.
Looking at other Bybee devices, some are partially magnetic, having what appears as magnetic end caps, and some leads are highly magnetic. These are the large and medium sized devices made over the last 15 years.
"Condemnation without Examination is Prejudice"
Old 6th September 2010, 04:50 PM   #452
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Are those the original small ones or the new "Slipstream" units? What are their dimensions?
se
The Audio Guild
Old 6th September 2010, 05:52 PM   #453
john curl's Avatar
The components that I am scraping the leads on, are the so called Slipstream devices that SY apparently has. They look visually identical to me. I also have medium sized and larger units that I showed SY one example of, years ago.
Old 6th September 2010, 06:09 PM   #454
john curl's Avatar
Jack Bybee says the leads are Copperweld, with silver plating. That is all that I have to say about the subject. This is necessary because the devices are welded together, rather than soldered internally. This means that iron is involved in the conductor.
Old 6th September 2010, 06:13 PM   #455
john curl's Avatar
If someone is located in the SF bay area, and is a moderator of this forum, and would like to impartially look and even test a selection of Bybee devices, just contact me and get on over here, and I will show you what I have, we can measure what we can, together, and you can take them home with you to test and try.
Old 6th September 2010, 06:34 PM   #456
Steve Eddy's Avatar
So what do you get with the silver and gold versions?
se
The Audio Guild
Old 6th September 2010, 06:47 PM   #457
PMA is offline PMA  Europe
PMA's Avatar
I would suggest to the testers not to check sound differences of the Bybees against integral undamaged cable, BUT against pieces of wire of similar length and diameter as Bybees leads, inserted into the original cable ....
Old 6th September 2010, 07:21 PM   #458
On Hiatus
SY's Avatar
John, I tried scraping as you suggested and indeed, the leads appear to be plated copperweld (i.e., copper-plated steel and highly magnetic). So much for the multigigahertz stuff you were throwing out there. And so much for their claims of copper leads. Are the silver ones also just silver plated copperweld? The gold ones?
Pavel, my speaker comparisons were against a 50 cent 0R027 current sensing resistor. Copperweld leads as well, not coincidentally (copperweld is cheap and rugged compared to pure copper).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th September 2010, 07:23 PM   #459
PMA's Avatar
Stuart, sounds very good.
Old 6th September 2010, 07:36 PM   #460
john curl's Avatar
SY, the copperweld comes apparently from making the resistor. Apparently, it does not effect the 'performance' however, the military often does mandate this, rather than pure copper. As you or anyone else refuses to believe what I state in any case, especially if it is just info from Jack Bybee, you can find out more for yourself, as I am not able to help further.
Closed Thread
Bybee Quantum Purifier Measurement and AnalysisHide this!Advertise here!
Info on Bybee Quantum Purifiers needed Peter Daniel Everything Else 68 19th December 2012 08:28 AM
Bybee Quantum Purifier Experience. mrfeedback Everything Else 321 27th August 2010 09:41 PM
diy bybee quantum purifiers? mbl Power Supplies 549 16th April 2010 10:38 PM
measurement and analysis tools D_Dubya Full Range 12 31st May 2008 02:07 PM
