| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#221 |
I think you are right. What other technical threads do you see where individuals don't just eventually do the tests and report on them. Here we see the same test, resistance of the resistor in parallel with the "actual" device, done over and over again. That's why I say this game is rigged and the usual suspects on this thread should hand over both the listening and the measurement task to someone who doesn't have a vested interest in the outcome. It can still be people here at DIY audio, but other people. It seems only fair to me. I agree with JC.
#222 | |
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
#223 | |
diyAudio Chief Moderator
#224 |
I have to say "ditto" to Salas' post above. How do you know that the tests will be rigged? How do you know that the people who have volunteered to test these are biased?
Is this simply jumping to conclusions about those involved? Do you have evidence or some proof to back this up? Some important reason? Please let us know. |
#225 | |
In other words, personal anecdotes are HS and not evidence of anything. But you know that. |
#226 | |
Even if that person performs splendidly in retrospect does it mean it was wise to give that person the keys to the kingdom. It is no different to the justice system in which jurors are chosen based on their impartiality. Everyone knows that even the most well respected member in the community will be excused from the jury if he/she is intimately connected with the defendant. In this case the defendant would be Bybee's device and the underlying principle it is proposed to work on, namely, non-locality and high temperature super-conductivity. This jury system is an example of USA law. I don't know about how it works elsewhere. Is this a confusing idea to anyone here? And please do not manipulate the response so that only the case of hyperbole is concentrated on. I have seen how that goes and is a diversion from what I'm talking about here, which is the real essential point. |
#227 |
Do you realize that there will be 2 technical runs and 2 panel DBT runs by 3 main operators in 3 different places in America?
#228 | |
I'm sure someone will catch this. I did offer myself to help with the listening test. But it was only to try to balance out what I perceived as a one-sided administation of it. Its always better to try to get as close to all neutral people as you can find rather getting an extreme and then balance it by the opposite extreme, which was me. Last edited by exeric; 2nd September 2010 at 12:36 AM. |
#229 |
Name the person and direct him the question. I can't answer that.
#230 |
Speakerholic
I have a strong opinion and I am very involved in it.
Those things better make a difference and I'm likely to skew the tests as much as necessary to ensure they do. If they don't, I am going to film what happens to them. Maybe I better be the last to "test" them.
| Info on Bybee Quantum Purifiers needed | Peter Daniel | Everything Else | 68 | 19th December 2012 08:28 AM |
| Bybee Quantum Purifier Experience. | mrfeedback | Everything Else | 321 | 27th August 2010 09:41 PM |
| diy bybee quantum purifiers? | mbl | Power Supplies | 549 | 16th April 2010 10:38 PM |
| measurement and analysis tools | D_Dubya | Full Range | 12 | 31st May 2008 02:07 PM |
