| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#1501 | ||||||
The specified test cannot be performed at the level I wish using off the shelf CVR's. Quote:
If the leads are steel clad with copper internal, the inductance will increase as skinning occurs. Quote:
Throw out the provided explanation guys, it's diversionary. Think ground loop, EMC, ferrite bead, rf intrusion. Forget Halleys comet.. Quote:
P/n: P10.0CACT-ND and BC 1.0W-1CT-ND. Cheers, John |
#1502 | |
Location: Scottish Borders - Kelso; on the famous Tweed River!
And maybee a full subjective test is in order? And here - taking a clue from fdegrave's response in a much earlier thread, it is essential that the system in which it is tested is suitable for purpose in so far as that it is a system which is accepted as giving the best possible analytical sound prior to insertion of the device. |
#1503 |
Eric,
Pics of a CVR. The theory is this: any current in space creates a magnetic field, right hand rule. The only way to stop this is zero current. Net zero current. A coax does this, coaxial microwave resistors count on this for net zero internal inductance, but the return current has to go somewhere, and it's that seperation that causes magnetic energy storage.. (note: inductance by definition is the relationship between the current within a system and the total energy stored within the magnetic field. Another method of zeroing the current is to have the currents flow through each other in a distributed fashion. This is what I do. In this pic, the current flows in the very top plate (clad perf on 100 mil centers) through one half the resistors. Note half the resistors have a blue insulating sleeve (kynar) keeping it from contacting the center plate. The current goes through half the resistors to the bottom plate. There, the current goes up the other half of the resistors to the middle plate. Within the distributed structure of the resistor matrix, there is very little stored energy as there is very little magnetic field. If you wished to calculate it, that's easy also. A pair will have about 200 nH per foot inductance. 1/4 inch is 200/(12*4), or 4.16 nH per resistor pair. This resistor has 20 pairs, so the overall inductance will be about 4.16/20, or 208 picohenries. You will not be able to measure this inductance regardless of the equipment you use. Note in the second pic where I tap for the voltage reading. Also note that this construct has no net external field, so the twisted pair cannot pick up any error from within. Cheers, John |
#1504 | |
Here I was rooting for the deflection of the electron beam in a vacuum to change. A nice demonstration of warp drive! I suspect a more reasonable test would have been to use a Time Domain Reflectometer and seen if the velocity of propagation changed in a conductor. Just for fun I decided to try my "Macrame" filter and see what it did to the propagation velocity in a cable. I used my TDR and a 75' cable. Attached are pictures of the results (Sorry my TDR is too old to directly provide data) The brightness to the right is the time marker or reference. It is the same in both tests. Jan, The image in the reflection is the most recent picture of me! ES Last edited by simon7000; 17th February 2011 at 02:48 PM. |
#1505 |
Just had to point out the most basic electrical concept: average electron velocity is proportional to current/conductor diameter.
So increasing electron velocity means you have decreased the conductor size or increased the current. The only effect on the signal is the change in LCR from the change in conductor size. IE as much effect as splicing in a 1 inch piece of 18 gauge speaker wire at the end of your 16 gauge run. (the 1 inch piece "increases electron velocity") |
#1506 | |
"...at the same current."
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#1507 | |
diyAudio Chief Moderator
| Bybee Quantum Purifier Experience. | mrfeedback | Everything Else | 321 | 27th August 2010 09:41 PM |
| diy bybee quantum purifiers? | mbl | Power Supplies | 549 | 16th April 2010 10:38 PM |
| measurement and analysis tools | D_Dubya | Full Range | 12 | 31st May 2008 02:07 PM |
| Info on Bybee Quantum Purifiers needed | Peter Daniel | Everything Else | 59 | 1st April 2003 02:56 PM |
| Page generated in 0.15714 seconds (79.95% PHP - 20.05% MySQL) with 11 queries |
