| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#1491 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Which measurements? Velocities of electrons?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#1492 |
no, the measurements that work for analysis of all other known physics stuff.
Must be time for another round up so here goes: A Bybee device has been measured for some standard electrical and physical properties using simple and repeatable protocols that were designed to assess whether the device was what it claimed to be and did what it claimed to do, or did anything different to a control device. It isn't entirely what was claimed physically, and it does do anything different from a control device (a standard resistor) to a reasonable level of confidence (-125db if I recall) Since then, no-one has reproduced the tests and found differently. Since then various claims and theories have been put forward ranging from ultra-low frequency to ultra-high frequency effects, temperature and a range of esoteric physical to subatomic effects. Some have postulated a currently unmeasureable and unidentifed property. To date, no data has been provided on listening tests either here or in the sibling thread set up for that purpose. Hence it is impossible to confirm or deny the device actually makes an audible difference that is identifiable and repeatable. Draw your own conclusions.
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report |
#1493 | |
Whilst in the hands of the objective tester, subjective testing was conducted but no subjective findings were ventured. The last time I stated these facts recently, my post was deleted. Eric.
I believe not to believe in any fixed belief system. |
#1494 | |
Banned
That is high praise indeed, coming as it does from a master of performance art such as yourself Last edited by jkeny; 17th February 2011 at 07:48 AM. |
#1495 |
Is that sour grapes I can smell from someone who wasn't allowed to use the forum for commercial purposes.
hoping to pick up some things. |
#1496 |
Banned
#1497 |
Again, I ask this question:
Why is the Bybee QP only available in audio circles, Why if it is so good at reducing noise isn't it readily available for general use! Why. |
#1498 |
Location: Scottish Borders - Kelso; on the famous Tweed River!
This goes a long way back. I am afraid that the participants here - whatever their stated stance in this matter - have from the outset taken a view, negative, positive, or, apparently, up close and personal, which cannot but colour their present day approach.
Further, in the 9 years since this link (Info on Bybee Quantum Purifiers needed), the thread in which the link appears is worth a quick scan. was posted individual's accuracy of hearing has undoubtedly deteriorated - . In the same period measuring techniques and equipment have improved. Yet here we are again, saying the same things as ever. And now we are expected to accept that a cheap resistor substitute will produce the same measured results as the 'specified' resistor. This may well be akin to saying that if we need to check out the claims made for a Bentley car then we can use a Ford as an adequate lab. substitution. [They are both automobiles, right?] Does a cheap carbon resistor measure identically - in all measurable aspects - to a highest quality certified resistor? What has happened to fdegrove? I miss his well mannered and usually positive posts. |
#1499 |
No, it doesn't. But there's no mention of cheap carbon resistors here. The reference resistor used is a metal foil.
If there's a sucker born every minute, where do the rest of them come from? |
#1500 | |
@abraxalito: It would be grand to see changes to the velocity of electrons, but what does that translate into in sonic terms? Would it change the pitch? (I'm only half kidding). The awards and testimonials for the Bybee are remarkable. Why has nothing been shown in measurements? If I claim that capacitor X sounds different from capacitor Y, then I can back that up with measurements. Ditto, power supplies, OPTs and other stuff. It's not so mysterious. John Curl did cap measurements decades ago. So why nothing like that for the Bybee? If it affects the signal enough to be heard by so many, why does that change not appear in measurements?
Take the Speaker Voltage Test! |
| Info on Bybee Quantum Purifiers needed | Peter Daniel | Everything Else | 68 | 19th December 2012 08:28 AM |
| Bybee Quantum Purifier Experience. | mrfeedback | Everything Else | 321 | 27th August 2010 09:41 PM |
| diy bybee quantum purifiers? | mbl | Power Supplies | 549 | 16th April 2010 10:38 PM |
| measurement and analysis tools | D_Dubya | Full Range | 12 | 31st May 2008 02:07 PM |
