Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Bybee Quantum Purifier Measurement and Analysis
Closed Thread
Old 16th February 2011, 10:48 PM   #1471
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by SY View Post
That's how the impedance was measured (8R test resistor, not 4). Not only no difference, the Z was flat to 40k. In series with a noise source (the second part of your post), null difference down to 8Hz, with or without signal averaging.
It's a resistor.
The only test schematic I have seen was the MB stuff, so I cannot make statements regarding your setup.
Yes, I agree it is a resistor. It is in parallel with some gobbltygoop, and the claims are that that "stuff" somehow works better than Maxwells demon. So, if you believe that I accept the device's operation as marketed, you know me better.. You also know that I can be the devil's advocate.
Now. If I were to test a resistor at any stimulus from DC to 1 gHz, I would worry about a few things.
1. What is the current path within the device. To wit, is this resistor a helix or a bifilar? They act differently at frequency.
2. How does the DC resistance of the unit compare to the inductive reactance the device will have when subjected to currents. Is the inductive reactance of the device more, less, or comparable to the resistance?
3. When I try to measure the voltage across the unit during high frequency excitation, how do I do this without loop trapping the time rate of change of the external magnetic flux? Or, is it possible to compensate for it?
These things are very important when trying to measure low impedance widgits. I've had to design and make sub nanohenry current viewing resistors to measure magnets for phase shift in the 1 to 10 hz range..
When I see that 4 ohm pic showing the ellipse, I say to myself: yo, dude....you'ze swamped da good stuff with reactive goop and non linear goop, how youze gonna see the ting you lookin fo???
Honestly, I've seen this problem for a decade now. Everybody thinks they can buy an off the shelf power resistor that will produce accurate results across the audio bandwidth. That's a bunch of melarky..
Eric
I'll post the design tomorrow if I can. I'm afraid a physicist toasted the unit I built for him, so I don't know if I can take pictures of it for you. I told em, 1 ampere...1 ohm...1 watt, don't go higher...1 ampere...1 ohm, 1 watt...max..
10 amps
for 5 minutes.
Unattended..
sigh
melted the solder..
The color code is now....black, black, black... with a tolerance band of...you guessed it.....black
Cheers, John
Old 16th February 2011, 11:07 PM   #1472
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by jneutron View Post
I recommend you get a better set of resistors. A 4 ohm load resistor and a current view resistor, perhaps .1 ohm, both with inductance below a nanohenry each.
Kind of specialist parts no? Do you have links, I'm curious Wouldn't the other wiring in the circuit contribute inductance well above this 1nH level, or is that unimportant here?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th February 2011, 11:19 PM   #1473
On Hiatus
SY's Avatar
The current view resistor is what I used as my reference- not at all exotic, easy to buy (Mouser), at least here in the US, and pretty cheap.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th February 2011, 11:27 PM   #1474
jkeny is offline jkeny  Ireland
Banned
Sy did you do any of this?
Old 16th February 2011, 11:29 PM   #1475
On Hiatus
SY's Avatar
I am testing the device's claims. There's nothing on their website about gigahertz.
Within the audio band to two octaves beyond, the impedance is flat.
It's a resistor.
edit: With steel leads (rather than the claimed copper), it would be expected to be noticeably inductive at very high (hundreds of megahertz) frequencies, just like any other component with steel leads.
Old 16th February 2011, 11:33 PM   #1476
abraxalito's Avatar
Where was the claim about 'electron velocity' again? We've seen no answer to that question I posted a while back. Any news?
Old 16th February 2011, 11:34 PM   #1477
On Hiatus
SY's Avatar
Already answered. I'm not feeding trolls.
Old 16th February 2011, 11:36 PM   #1478
Banned
Just for the record - what was the answer? AFAIR you had devised a "very clever" way of testing for "electron velocity". So what had this to do with the claims??
Old 16th February 2011, 11:36 PM   #1479
abraxalito's Avatar
Already answered.
Just post up the link to it please, I must have missed it.
IOW, ex cathedra.
Old 16th February 2011, 11:37 PM   #1480
On Hiatus
SY's Avatar
Originally Posted by jkeny View Post
Just for the record - what was the answer AFAIR you had devised a "very clever" way of testing for "electron velocity". So what had this to do with the claims??
I'll let you do your own reading.
Closed Thread
Bybee Quantum Purifier Measurement and AnalysisHide this!Advertise here!
Info on Bybee Quantum Purifiers needed Peter Daniel Everything Else 68 19th December 2012 08:28 AM
Bybee Quantum Purifier Experience. mrfeedback Everything Else 321 27th August 2010 09:41 PM
diy bybee quantum purifiers? mbl Power Supplies 549 16th April 2010 10:38 PM
measurement and analysis tools D_Dubya Full Range 12 31st May 2008 02:07 PM
