| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I was wondering Is there anything like this in IT equipment ? I had this problem of power supply loops & motor boating when i was young diy..in the early eighties..but always found the solutions myself..BUT in my home network setup..I was disgusted with so many power adapters each feeding various devices, I want to know whether if i can connect the wireless router (Airlink 101) & Siemens broadband DSL modem on a common power supply of 1.5 Amps both using 12 Volts.(Airlink draws around 250~300ma & DSL modem 300ma MAX)
The ethernet port of Modem connects to internet port of the router. Is it safe to to run both on a common supply..will there be any loops in the "LAN" cable ???
SivanandBalan |
#2 |
Ethernet is AC coupled so no problems.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
how ? pls explain ..(ur dealing with high speed digital signals)
SivanandBalan |
#4 |
I haven't been able to determine whether or not ethernet is required to be AC coupled, but it is 2, 3, and 5 voltage level differential bipolar signaling (AC) depending on the speed.. Given it is differential it would likely be AC coupled but isn't necessarily so, however IIRC pulse transformers are pretty commonly used in ethernet applications..
Ethernet - Wikipedia, the free encyclopedia Ethernet over twisted pair - Wikipedia, the free encyclopedia Ethernet physical layer - Wikipedia, the free encyclopedia Seem likely to me that it would be AC coupled precisely to avoid issues with ground loops.
www.kta-hifi.net Last edited by kevinkr; 25th August 2010 at 04:05 PM. |
#5 | |
SivanandBalan |
#6 |
Every Ethernet port I have seen is transformer coupled.
#7 |
In the DSL side its a/c coupled (telephone line) to a balanced transformer..but ethernet side is not sure..goes straight to a IC chip & could see chip caps around.
SivanandBalan |
#8 |
Except for: Power over Ethernet - Wikipedia, the free encyclopedia which cannot be isolated
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#9 | |
SivanandBalan |
#10 |
Not sure if that is a question, but no, if DC is flowing between 2 devices, they simply cannot be galvanically isolated, even if there is is one of those pulse tranformers on the signal circuitry.
| Ground loops and containment | jneutron | Parts | 49 | 18th February 2011 02:28 PM |
| resonant loops | Notagenius | Parts | 0 | 12th October 2007 08:16 AM |
| nested feedback loops | AndrewT | Solid State | 5 | 13th September 2004 10:45 PM |
| P3A and ground loops | biff584 | Solid State | 5 | 14th March 2003 02:21 PM |
| Earth/Ground Loops | JohnClark | Tubes / Valves | 2 | 14th November 2001 12:49 AM |
| Page generated in 0.11651 seconds (79.34% PHP - 20.66% MySQL) with 10 queries |
