Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd August 2010, 10:55 AM   #1
Default First try in making an active crossover. Not working.
Hey everyone,
It is my first try in making an active crossover circuit using two TL072 to drive a 4ohm woofer, first TL072 for the buffer and the low pass circuit, the second TL072 for the lowpass equalization. So no sound comes out through the 3rd stage, how come?
Circuit is Similar to this http://www.linkwitzlab.com/images/protos/w-xo-lp2.gif i checked everything out twice but nothing yet... could it be overdriven?
Old 22nd August 2010, 12:17 PM   #2
Banned
Woofer impedance is irrelevant.
What amplifiers are you driving with these crossovers?
w
Old 22nd August 2010, 12:20 PM   #3
Woofer amp by the way is LM3886 non-inverting.
Old 22nd August 2010, 12:29 PM   #4
For testing purposes:
mp3 player>headphone amp>the above mentioned crossovers>Linkwitzlab LM3886>4OHM speaker
here is the schematic of the amp:
http://www.linkwitzlab.com/images/graphics/3886pwr.gif
Old 22nd August 2010, 12:37 PM   #5
Also tried this one(woofer stage only):
But not working either
Old 22nd August 2010, 01:45 PM   #6
just another
wintermute's Avatar
Hi Junesony, I hope you are using that as a line level crossover (ie before the amplifiers) and not putting it between your amp and speakers a number of things in your post lead me to think that you might be though.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 22nd August 2010, 05:20 PM   #7
Tony.
Hello Wintermute, yes i hope it is correct placement of a line level crossover... this is how i did it:
source->FIIO5 headphone amplifier->active crossover->LM3886 amplifier->4ohm speaker
Do you think i should do away with the headphone amp?
Old 22nd August 2010, 06:42 PM   #8
the 3 stages of your crossover are dc coupled. It is possible that you driven the 3rd stage to the positive or negative rail?
Old 22nd August 2010, 06:53 PM   #9
Frank Berry's Avatar
How are you powering the active crossover? I'm assuming that it's a bipolar power supply with something like +15 and -15 volts.
A little bit of d.c. offset on one of the stages shouldn't stop the entire crossover from working. Perhaps one of the chips is bad. Is there audio on the output of the first and second stages?
Frank
Old 22nd August 2010, 06:56 PM   #10
The schematic is not an amplifier. It's a power supply.
I assume that this schematic was posted in error.
Frank
Making 3rd order crossover silentblackhat Multi-Way 1 12th September 2006 02:07 AM
active crossover power supply pcb check before making mazurek Solid State 20 2nd May 2006 12:17 AM
active crossover power supply pcb check before making (was in wrong forum) mazurek Power Supplies 0 29th April 2006 10:25 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.09718 seconds (81.15% PHP - 18.85% MySQL) with 10 queries
