New Linear Audio publication! - Page 62 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 24th May 2013, 03:56 PM   #611
Ahh, good - thanks John. I don't feel so alone now.
A pcb layout?
The number of ICs are 'new territory' and the signal electrolytics caps are quite foreign, despite the page 162 explanation - perhaps film caps could be subbed for the smaller ones, but not sure about the larger ones - bipolar? anti-parallel?
I wonder if a 'Cross Feed' cct for headphone amps could be included somehow?
Old 24th May 2013, 05:33 PM   #612
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Elna RFS, ref. the measurement by Mr Pass, don't break the bank either in most values.
(1st series Silmic's were also rather silky smooth, imo)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 25th May 2013, 04:17 AM   #613
There's quite a few of them - four directly in the signal path with low/no voltage bias over them - and all over the tone controls ...
Perhaps these don't effect the 'quality of the sound' after all?
Old 25th May 2013, 04:56 AM   #614
Fanuc is offline Fanuc  United Kingdom
Originally Posted by jackinnj View Post
The Jung regulator articles are archived on Walt's website: Home
Sadly the PCB is now unobtanium. The bootstrapped '95 one with AD797 I am on about. The newer design with AD825 and floating pre-reg was a complete waste of space.
PS. I am not criticising the PCB layout of the newer versions or ALW's PCB layout etc. In many cases this this was probably better.
Their was just something better about the original. Like a good aged whisky.....
Old 25th May 2013, 08:32 AM   #615
jan.didden's Avatar
I layed out the original, when I was still tender, and didn't have the acres of layout under my belt I have now. Looking back on it I don't feel it looks particularly 'nice' (will never make a glossy product picture ) but it did work quite well.
Maybe I should do a reprise?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 25th May 2013, 02:03 PM   #616
jan
Dear Jan,
I really think you should, but remember you need to allow provision for T-O3P, TO-264 and such like for people with larger members in mind! :-)
Remember, it is going to take 100 Farad at least of the finest quality high ripple capacitors available, possibly up to 1000 Farads of this capacitance to remotely equal the performance of these regulators with respect to feeding the output stage of a power amplifier.
Let us not even get into remote sensing and fully balanced amps just yet....oh and forget the Wurcer cap mod with the AD797 whilst your at it....
Load protection is another issue that needs discussed when output transistors short circuit. VI is not that good esp. with mosfets.
Will be in touch
Kevin
Old 25th May 2013, 02:12 PM   #617
jan.didden's Avatar
Kevin, no offense, but I don't have the time nor ambition to embark on a one size fits all project - I've seen too many projects get grounded here after a lot of effort and endless discussion whether the cap should be red or green.
My offer was for a new layout of the 1995 superreg.
But don't let me hold you back
jan
Old 25th May 2013, 02:15 PM   #618
buzzforb's Avatar
Jan,
Is it possible to increae output volrage without too much trouble and still mainatin performance. I would like to compare your/Jung reg to Salas Shunt I am using in a Phono stage
...Shape the sound , Man!
Old 25th May 2013, 03:16 PM   #619
jan.didden's Avatar
You can play with the feedback voltage divider to set Vout, or with the reference, or both. I think the limit is the max Vsupply for the opamp.
There will be *some* change in performance but too small to measure unless you've got Jack's setup.
jan
Old 25th May 2013, 03:21 PM   #620
buzzforb's Avatar
I remember looking into it and thinking you guys were pretty close to the max output. I do believe it was related to the opamp limits. I was hoping to get to the 36V region. I have contacted peranders about his sjolstrom regulator. It is also limited as far as higher voltages are concerned. Thanks for the time and suggestion.
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 11:00 PM
PS Audio Linear Control Center and Phono III tomman888 Solid State 2 16th May 2009 10:21 PM
Linear Regulators eranrund Power Supplies 10 11th August 2008 09:11 AM
publication mikek Solid State 0 4th August 2002 04:53 PM
Copyright ©1999-2017 diyAudio
