New Linear Audio publication! - Page 12 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st September 2010, 09:18 PM   #111
jan.didden's Avatar
Originally Posted by pooge View Post
But I don't see any "compensation" as I understand it in Leach's approach.
The Leach Amp - Feedback Network
It does not "compensate" the overall global feedback path when the global feedback path is in operation. It replaces the "global" feedback path starting at the driver stage at high frequencies.
Again, semantics may play a part, here. I was never comfortable with Leach's term "feedforward compensation" for this, either. This reminds me of the transconductance doubling debate they had between them. When it came down to it, they both had a different definition of what class AB was.
Well, it compensates the global amp without the output stage. As the output stage is nominally unity gain, you could argue that it compensates the amp gain transfer function (because that's what it is about; it's not about compensating the feedback loop as such).
But I agree that his use of 'feedforward' is confusing if not plain wrong.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 21st September 2010, 09:53 PM   #112
pooge is offline pooge  United States
Ain't semantics a beotch?
Old 21st September 2010, 10:00 PM   #113
jan.didden's Avatar
Old 22nd September 2010, 02:28 PM   #114
DouglasSelf's Avatar
The compensation in the Leach design is the two Miller dominant-pole capacitors C3 and C4, and this appears to be conventional. As Pooge rightly said, the Leach scheme replaces the outermost or global feedback path with another path fed from the VAS stage at high frequencies. The first diagram caption refers to the "feedforward feedback network" which is a touch opaque. I think it's a misuse of the word "feedforward" and what was meant was that feedback is taken from somewhere forward of the output.
It would appear the design was simulated but not measured. Making an amplifier is not just about Nyquist stability around the global feedback loop- that's relatively easy. What's harder is making sure that reactive loads don't trigger local parasitic oscillations in the output stage. SPICE does not, in my experience, offer enough detail in its transistor models to simulate this, and I can't help wondering how well the design would work in reality.
Output inductors are not that expensive in production. I always use them.
Douglas Self
Old 22nd September 2010, 02:45 PM   #115
The Leach amp incorporating this scheme has been around for over a dozen years. So yes, it has obviously been measured. There is also a SPICE for his circuit on this page:
Leach Amp Plans - Part 1
However, the alternate global was moved from the VAS to the predriver, for reasons mentioned in his article.
Old 22nd September 2010, 02:53 PM   #116
The design your link points at doesn't have a feedback path from the VAS, though there does appear to be some sort of feedback path from the driver stage via C9 and R20. I'm not sure what that's supposed to do.
And it DOES have an output inductor. This is not the same amplifier.
Douglas Self
Old 22nd September 2010, 03:09 PM   #117
Then it is not a matter of semantics. You just haven't read it.
And to think, you guys invented English.
I already posted this link.
Old 22nd September 2010, 05:24 PM   #118
I haven't got a clue what your complaint here is, but you might try to be polite about it.
Douglas Self
Old 22nd September 2010, 06:21 PM   #119
My complaint is that you steered the discussion off topic by dissing me in post #116 by stating my reference examples were somehow faulty because they were not the same amplifier (because the the feedback wasn't from the VAS and it had an output inductor). The original article, in the first paragraph of page 338, states:
"This positive feedback could be minimized by choosing the v, node to be a lower impedance point in the circuit, e.g. C2 could be connected to the emitter of Q7 (node 17) rather then to its base."
Therefore, Leach's amp clearly follows this tweek in the article, and therefore CLEARLY follows the article's teaching. I'm pretty sure MOST people would regard it as the same amp, at least for the benefit of the present discussion. The fact that he added an output inductor as an extra measure is totally irrelevant!
You have dissed the output triple for years as being characteristically unstable, yet the Leach amp is a very well known, rock stable design, even into electrostatic loads. Curiously, in your writings, you promote the advantages of a buffered VAS, which resembles the predriver of a triple.
As Leach's writings have been publically available for at least a decade on-line, and I know you are fully capable of understanding them, and many many amps based upon this design have been successly built, it makes me suspect that you have not read his available publications, which would surprise me, or that you have some other motive for minimizing the technology he has published.
Old 23rd September 2010, 06:39 AM   #120
Mooly's Avatar
Pooge,
nobody is "dissing" anybody... I looked at your links, and to me they don't appear to show what you are trying to discuss. The feedback comments relate to the circuit you posted the link too, and that doesn't have the feedback network you are talking about.
It's not up to the reader to go hunting through pages of stuff (where ever they may be)... and I haven't a clue what and where "page 338" is.
Don't assume knowledge or that everyone knows what you are talking about
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
PS Audio Linear Control Center and Phono III tomman888 Solid State 2 16th May 2009 09:21 PM
Linear Regulators eranrund Power Supplies 10 11th August 2008 08:11 AM
publication mikek Solid State 0 4th August 2002 03:53 PM
Copyright 1999-2017 diyAudio
