Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
New Linear Audio publication!
Old 26th May 2013, 06:44 AM   #631
dchisholm is offline dchisholm  United States
dchisholm's Avatar
Originally Posted by Fanuc View Post
Sadly the PCB is now unobtanium. The bootstrapped '95 one with AD797 I am on about. . . .
It's definitely impressive when an engineering effort "gets it right the first time".
Are you referring to the schematics of Figure 1 and Figure 2 of the article in "Audio Electronics", 2000 issue #4 (see http://waltjung.org/PDFs/Improved_PN_Regs.pdf ). I believe those circuits use a slightly modified version of the PWB layout shown in Figure 4 of the "Audio Amateur" article from 1995 issue #3 (see http://waltjung.org/PDFs/Regs_for_High_Perf_Audio_3.pdf ).
If that is the case, it should be fairly straightforward to simply replicate that layout into a file package that you could successfully send to most of the quick-turn PWB houses. Since the component make/model and basic mechanical layout have already been determined, I'd estimate about 1 - 2 man-days' work. Of course, modifications or "requirements creep" can exponentially increase that estimate.
Dale
Old 26th May 2013, 07:43 AM   #632
Fanuc is offline Fanuc  United Kingdom
Dale
Hello,
It would better if Jan designs it. I know he done tests/measurements (no easy task I hear)for Andy (ALW) and liked the PCB layout etc. I remember following the thread at the time. So he's best placed to design/improve it etc.
Kev
Old 26th May 2013, 01:22 PM   #633
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Peranders boards are to be recommended. Here are the Old Colony boards which Jan designed:
At some point I will reconfigure to the shunt design WJ discussed a few months back in AudioXpress.
Old 26th May 2013, 06:35 PM   #634
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I've layed out a revised version, using the original circuit from the 1995 series updated with Walts 4/2000 article in Audio Amateur (all available on Walt's website).
I need to do some small tuning but will then place the Gerbers and stuff on my website for free.
Single board for pos and neg version which can be separated.
Such is the pleasure of a rainy Sunday afternoon
jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 26th May 2013, 06:37 PM   #635
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Thanks, i will try it.
Old 27th May 2013, 07:41 PM   #636
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by peranders View Post
who will build Bruno's
A Bruno-VC thread might be a stimulant.
e.g. BOM, tips on how to handle that buggar, possibly a component GB (+ang).
Just staring at the C-numbers makes me feel somewhat challenged.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 27th May 2013, 08:08 PM   #637
jan.didden's Avatar
Jacco, any problem to translate that post into English??
jan
Old 27th May 2013, 08:15 PM   #638
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
jan
Q1? Check the placement against the heatsink.
Notice also that you have acid traps (angles less than 90 deg) on the pcb, near J1 for instance. I don't use square pads very much. Pretty tight in some locations.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 14 pcb's in interest.
Old 27th May 2013, 09:05 PM   #639
jan.didden's Avatar
Yeah I need to check those pinouts. The PCB faithfully reproduces the schematic, but those libs always have multiple pinouts for the same case. Standard procedure, I learned that the hard way
jan
Old 27th May 2013, 09:16 PM   #640
peranders's Avatar
It looks like you are using Altium Designer and if so I really do recommend that you make a pcb project with schematics and layout. Then you can also put intelligent net labels in the schematic and have a nice overview in the layout.
New Linear Audio publication!Hide this!Advertise here!
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 11:00 PM
PS Audio Linear Control Center and Phono III tomman888 Solid State 2 16th May 2009 10:21 PM
Linear Regulators eranrund Power Supplies 10 11th August 2008 09:11 AM
publication mikek Solid State 0 4th August 2002 04:53 PM
