Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
New Linear Audio publication!
Old 25th May 2013, 04:57 PM   #621
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I believe that 36V should be possible, but I need to check.
BTW Did you read Jack Walton's comparative power supply test, measurements and listening tests, in Linear Audio?
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 25th May 2013, 05:01 PM   #622
buzzforb is offline buzzforb  United States
buzzforb's Avatar
That is the seed that spring the question.
...Shape the sound , Man!
Old 25th May 2013, 05:12 PM   #623
jan.didden's Avatar
In the interest of reliability, the raw input voltage should not be higher than the total opamp allowed sypply. So for the most opamps that's 36V, but some allow 44V.
Anyway, if the raw input is 36V max, the Vout max should not be higher than (precision guess) 32V or so.
Some safety factor, limit Vraw to say 33V and Vout max to 30V.
Is that not enough for almost all applications?
jan
Old 25th May 2013, 07:54 PM   #624
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I gathered, Mr Walton is a Jack of all John's.
Old 25th May 2013, 07:57 PM   #625
buzzforb's Avatar
jan
I need 36 for the phono. Oh well.
Old 25th May 2013, 08:29 PM   #626
jan.didden's Avatar
One extra zener will do it
Old 25th May 2013, 08:42 PM   #627
buzzforb's Avatar
Opa627 will do 36v. What op amp were you considering? I'll try to start fiddling with schematic.
Old 25th May 2013, 08:47 PM   #628
Fanuc is offline Fanuc  United Kingdom
Hello,
What phono stage needs 36 volts anyway ? Is it AC coupled or a tube design? SOme of the lowest noise jfets with high gm will struggle with them voltages.
Most are under +/- 24volts DC...and even that can be pushing it
Kev.
PS. You can cascode the input CCS to waste unloaded headroom or change op amps.
Old 25th May 2013, 09:00 PM   #629
buzzforb's Avatar
Originally Posted by Fanuc View Post
Hello,
Kev.
Salas folded simplistic.
Old 25th May 2013, 09:17 PM   #630
This should read a cascoded CCS with high gm mosfet output (or possibly pre-load the output) could be used to waste unloaded voltage headroom. I am going to dig out the original PDF and have a re-read. Make sure I am up to speed on it.
A small heatsink is advisable on top of the op amp also. You could also use very linear super-beta type transistors if it's just for a single positive rail.
New Linear Audio publication!Hide this!Advertise here!
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
PS Audio Linear Control Center and Phono III tomman888 Solid State 2 16th May 2009 09:21 PM
Linear Regulators eranrund Power Supplies 10 11th August 2008 08:11 AM
publication mikek Solid State 0 4th August 2002 03:53 PM
