Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th July 2010, 01:36 AM   #1
unclejed613's Avatar
Default Vintage audio trivia question
ok, i don't have tickets for two on a Riviera cruise... i don't even have two cents to rub together sometimes, but here's one that should have everyone digging out old service manuals...
A manufacturer of high end preamps and power amps in the 1980's had a small unobtrusive joke in the service manual for their preamp line. the joke is this, the "Tone Defeat" switch is marked in the schematic with two positions... Defeat and Victory. Which manufacturer, and which preamp?
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 17th August 2010, 11:11 AM   #2
bzzt! time's up.... Apt-Holman preamp.......
Old 17th August 2010, 08:50 PM   #3
Pano is offline Pano  United States
Pano's Avatar
That is Trivia indeed! Pretty good.
I remember a manual that had the name "Zaphod Beeblebrox" used in several examples.
But that was for a hi-res camera, not audio.
Old 17th August 2010, 09:27 PM   #4
tomi is offline tomi  Wales
Location: Aberystwyth and Manchester, depending upon term times.
I remember hearing a tale of a service engineer who encountered a test point on a board labelled AFTP, which was not mentioned in the manual.
Upon making enquires with the manufacturer he was informed - with much mirth - that the label denoted "Another F****** Test Point".
The Geek shall inherit the Earth.
Old 17th August 2010, 11:22 PM   #5
Enzo is offline Enzo  United States
OK, one of my favorites:
WHich processor had separate power and glory switches?
The Rane PI14
Please check it out here:PI 14 Pseudoacoustic Infector
And data sheet: http://www.rane.com/pdf/pi14dat.pdf
Old 17th August 2010, 11:25 PM   #6
And check out the Palindrometer from the boys at Funk Logic.
Funk Logic - 3P-III Palindrometer
Old 17th August 2010, 11:31 PM   #7
Pano's Avatar
Wow, that rules!
Take the Speaker Voltage Test!
Old 18th August 2010, 11:00 AM   #8
i don't remember the processor with Power and Glory switches....
i used to have a copy of a TI data sheet. apparently in the early days of making their LEDs, about half of the LED dice worked and half of them didn't because the process was new, and not completely reliable. so an engineer came up with a use for the half that didn't work.... the DED (Dark Emitting Diode) and published a data sheet for them... i wish i still had that one, because i can't find a copy on the web... i also used to have the National Semiconductor data sheet for a POP-amp and the Signetics Write-Only-Memory.... there's also a MSDS sheet for Dihydrogen Monoxide
there was a company that made RS-232 video terminals, SOROC. the origin of the company name? it's an anagram for COORS (as in beer)...
Old 18th August 2010, 11:13 PM   #9
I have a Mackie equipment brochure that lists, in the specification section, the weight of the Corporate Chihuahua. (Use Google to search for Mackie "Corporate Chihuahua".)
Old 19th August 2010, 12:53 AM   #10
Ron E is offline Ron E  United States
Ron E's Avatar
http://www.mackie.com/products/hdr24...HDR_Insert.pdf
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Analog Devices 40th B'day Trivia Contest jackinnj Everything Else 0 8th October 2005 01:12 PM
Music trivia! jeff mai Music 24 8th March 2005 09:24 AM
Tube manufacturer Trivia Question planet10 Tubes / Valves 24 10th October 2004 11:31 PM
Page generated in 0.09992 seconds (77.10% PHP - 22.90% MySQL) with 10 queries
