Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd July 2010, 11:28 AM   #1
Default AC house wiring
I'm modifying my apartment, and everything will change. One if them is the AC wiring.
Where I live (Brazil) we have what we call 3-phase wiring, that is we have three live wires and a ground. Combining one live and one ground wire you get 110v, if you combine two live wires you get 220v.
On my past two houses I assembled it in such a way where I would put all high-current stuff (washing machine, fridge, etc.) on one wire, computer on a second and audio/TV on a third. AC units are 220v over here, so I would wire them accordingly, on separate protection switches.
There's some advise I would be grateful to have on two matters at least:
1) What wire gauge should I use for the audio/TV wiring?
2) As I am considering buying my wall apppliances in the US, what brand and type would you recommend? Any best place to buy them?
Thanks,
Carlos
Old 22nd July 2010, 12:46 PM   #2
zigzagflux's Avatar
You may have your terminology off a little. You say you have three phase, but the system of 110/220 you describe is split single phase. Both of these systems are 3 wire plus ground (with some three phase systems being 4 wire plus ground). A three phase system will have line-neutral (ground) voltages differ from line-line voltages by 1.732. So a three phase system would be 120/208, not 110/220. So the first thing you need to do is resolve what you actually have to work with.
That being said, your general best bet is to load your system in a balanced manner, which is better for voltage drop and better for the utility grid. So putting all high current loads on one leg sounds good, but doesn't really provide any benefit for your audio system. There are advantages to placing sensitive loads on their own breaker, or in the extreme using an isolation transformer for that circuit, but we're talking an apartment here (which to me implies renting).
As far as wire gauge, just follow the NEC. An A/V system does not draw that much power, such that an increase in wire size will significantly affect operation. If you are dealing with a 500 foot run let's discuss.
Appliances, a can of worms. All I can say is avoid Viking like the plague. Worst quality and customer service, although you pay three times as much for the same hardware.
Old 22nd July 2010, 04:38 PM   #3
Thanks for your advice.
My terminology is not off, it's the way it's called here. It's called trifasic. Maybe it's what it's called split single-phase in the US. Trifasic started as an industrial application use, then passing on to home use.
Not, it's not rental, we own it. In a rented house you can not do what I intend to do, which is destroying the whole apartment.
Some load will be on separate breakers, like air-conditioners, but not the rest. What I will try to provide are separate breakers to audio, TV and computer.
What I do not want is noise or spikes coming from home appliances polluting those more sensitive lines, or RFI coming from the computer affecting audio/TV AC lines.
Where do I get the NEC table?
The apartment is 110 square meters, and I don't know much how that is in US feet. By my counts I shouldn't exceed 100 feet for any wire run, I think, maybe 200 Ft..
I was considering Pass & Seymour or Hubbel.
Old 22nd July 2010, 10:20 PM   #4
Speedskater's Avatar
"NEC" is the US National Electric Code. 2008 is the current version but 2011 will be out soon. This rule book is well over 800 pages long. Most of can be found searching the web.
Jim Brown of Audio Systems Group (also a AES committee chair) recently released an international version of his paper on audio systems and AC power.
http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf
Kevin
Old 23rd July 2010, 07:19 PM   #5
zigzagflux's Avatar
If that's the case, you either have 110/190 or 127/220. It's not that I insist you have single phase, I'm just saying three phase (triphasic) 110/220 is impossible, no matter where in the world one lives. The numbers point to single phase, while your description points to three phase.
LOL. Sorry. I was assuming you were talking about refrigerators and stoves. Yes, P&S or Hubbel are very good choices.
Old 25th July 2010, 03:25 PM   #6
dudaindc's Avatar
Approximately 1100 square feet - 1184 ft2 to be more precise.
Old 25th July 2010, 04:27 PM   #7
AndrewT is online now AndrewT  Scotland
precise indeed, error less than 26ppm.
regards Andrew T.
Old 25th July 2010, 04:56 PM   #8
diyAudio Moderator Emeritus
jean-paul's Avatar
A good read, thanks !
It's only audio
Old 25th July 2010, 06:16 PM   #9
dudaindc's Avatar
Old 26th July 2010, 04:49 PM   #10
Yes, you're right. It's 127/220v.
AC wiring heaters, A or B ? zigzagflux Tubes / Valves 10 4th July 2008 09:43 PM
WTB: Analog AC Ammeter - AC Voltmeter - Panel Mount dBfreak Swap Meet 1 16th March 2007 10:41 PM
Overvoltage on house wiring Bama Slamma Everything Else 15 30th November 2006 03:45 AM
PS question- Need to get 20V AC from 60V AC - w/o Trafo lgreen Pass Labs 9 2nd January 2004 10:31 AM
HUBBELL IG3800 clones? AC sockets /AC wire jasonruiz Parts 5 25th April 2003 10:21 PM
Page generated in 0.12260 seconds (82.29% PHP - 17.71% MySQL) with 10 queries
