Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 2nd July 2010, 08:27 PM   #1
gain-wire's Avatar
Default Inductor in very big values (500mH, NOT for crossover)
I didn't bother to do a search honestly, because I figured no one would have the answers to both of my questions.
First, I am wondering why it is that it's so difficult to find inductors or chokes over a couple mH anywhere. It seems as though no one makes these. I need something in the area of 200mH to 1H for an LC-based audio filter.
Second, have any of you compared the quality of the budget-friendly LCR meters available on ebay? I want to know why they are so cheap while classic LCR bridges from HP, Fluke and other notable companies remain over 200$.
thank you for your help,
gain-wire
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 2nd July 2010, 08:44 PM   #2
I suggest you use an active filter and eliminate the need for the large inductor.
Old 2nd July 2010, 09:28 PM   #3
bear's Avatar
The way to get inductors of this size is to use some sort of core, laminated core, like a transformer. You size the core and type and gapped or not depending upon the application. They are sold. The Japanese use them all the time. UTC made them for audio, others did and may still.
The primary and secondary of an ordinary audio transformer can be used as well - depending again on the DC or lack thereof...
The cheap imported "digital meters" basically are oscillators that then coordinate the resulting frequency with an inductance value. The more expensive meters or bridges can deal with other parameters (such as "Q") as
well as measuring at different frequencies and power levels...
I'd look for a nice bridge.
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 25th April 2011, 08:43 PM   #4
akis is offline akis  United Kingdom
Hi
I also want a 500mH coil for an audio circuit. I tried winding my own on a old AM/FM radio ferrite rod which is 12 cm length and 1cm diameter. After I wound almost the 11cm I measured 6.87mH... Almost 80 times less than what I need.
I looked in Farnell and they have a ready made 500mH - not sure if it will work
BOURNS JW MILLER|70F501AF-RC|INDUCTOR, CHOKE | Farnell United Kingdom - but I will get it anyway.
Ideally I would like some sort of heavy-duty ferrite cores where I could wind my own coils to reach 500mH without needing millions of turns. Do you know if any retailers have them?
Old 25th April 2011, 08:57 PM   #5
About the cheap LCR meters on ebay. The cheap one I bought sure is handy but
the inductance readings are about 10 to 20% off.
Old 25th April 2011, 09:00 PM   #6
infinia is offline infinia  United States
infinia's Avatar
a ferrite bar has a very large gap in the magnetic path, so the Al value is low.
get a core catalog 1st and then you will find non-gapped toroids or pot cores or other magnetic stuctures and materials that will give reasonable turns. You must check for the desired Q and also make sure it will meet any linearity targets (ie saturation) over the DC and AC signals present, steady state or under transients from your application.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 25th April 2011, 10:09 PM   #7
DF96 is offline DF96  England
Typical ferrite rod inductances will be a few hundred uH for MW and a few mH for LW, depending on how many turns are used. For 500mH you need a ferrite pot core.
Old 26th April 2011, 08:52 AM   #8
I just discovered farnell have the RM10 ferrite pot and bobbins and have ordered a couple to play with.
Old 26th April 2011, 09:52 AM   #9
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
For an audio circuit, you might be able to get away with a synthetic inductor, otherwise known as a gyrator. With RM10 you'll likely need around 180 turns to reach a value of 500mH as the AL value I found is 16uH/N^2.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 26th April 2011, 10:35 AM   #10
gain-wire
Audio Transformers By Cinemag Inc.
Tannoy Eaton Inductor Values & Crossover Advice Thomo Full Range 0 31st October 2009 10:39 PM
D2Audio Inductor Values tripathdude Class D 0 26th September 2009 02:50 AM
Inductor values in crossover? googler Multi-Way 1 3rd August 2005 03:50 PM
Inductor values ? timcow Parts 2 31st July 2004 01:22 PM
help with inductor values on legacy crossover? confused Car Audio 0 14th March 2004 08:10 PM
Page generated in 0.10489 seconds (78.00% PHP - 22.00% MySQL) with 10 queries
