| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
As I've looked at the different categories and had no luck.
Here goes. My problem is, I'm getting older (at my age I've probably GOT older ) and my hearing isn't what it used to be.However, if I 'increase my effective ear area' by placing my cupped palms behind them I get a much clearer sound picture. What I want to know is, are there any sort of 'plastic reflector-type gizmoes' that will give the same effect as the cupped hands idea? I'm aware of lots of 'hearing aids' out there but that ain't what I'm looking for. No doubt there will be many bizarre solutions forthcoming but, maybe somewhere amongst them, a solution will surface. ![]() Best regards, 'Frustrated' Jim. |
#2 |
To start with you could get your ears cleaned at the doctors.
You will have to drip the ears with a special cleaning fluid for a couple of days, and the the doctor takes a syringe with 1 liter(!) of water and 'hose down' your inner ears. I had this done a couple of days ago - it is amazing how much cr¤p ends up inside ones ears, and now i hear better than ever.
STOP - Hammertime! |
#3 |
I know exactly what you mean, I'm fairly deaf and have found the same thing. Maybe a winged chair back could be made to have a similar effect.
Either that or a natty hat with attached ear trumpets! Imagine the arguments that would ensue about whether a natural woollen hat had better mid range clarity than a synthetic one. Any younger readers here should take notice of the deaf. Use ear protection, it will be the biggest sound upgrade you can make for when you are 50! John |
#4 | |
GENIUS I SAY! but seriously, go get them cleaned first. |
#5 | |
Nevertheless, Best regards. Jim. |
#6 | |
(If I had a dog I would have got some funny looks) Headphones would be OK if I could get something like the Sennheisser HD414 which were the mut's n^%s in the 'sixties. Tjhey were light, very clear and didn't have whopping great muffs on them. i wonder what's available these days. Still experimenting though. Jim. |
#7 | |
Banned
If you're having hearing difficulty, get it investigated. It might be a progressive condition that is nevertheless arrestable with treatment. At least find out the extent. A simple test you can do on yourself is to wear earphones and play a rising tone generated with software. This may give you some indication of what is going on, but you should at least ask a GP (if not a specialist) for an opinion. I had a friend who ignored what he thought was a trivial condition. In the end had to give up the saxophone and now endures a socially isolating near-total deafness. If nothing else a doctor can reassure you that the issue truly is trivial. w |
#8 | |
But thanks for that I'll speak to the local 'quack' Best regards, Jim. |
| Daft Hybrid Amp | 316a | Tubes / Valves | 1 | 13th June 2009 08:40 AM |
| Using 20 bit data with a pair of old 16 Bit DAC | stefanobilliani | Digital Source | 15 | 14th January 2007 12:55 AM |
| Daft photographs | EC8010 | The Lounge | 7 | 29th August 2006 01:41 PM |
| 24 bit I2S source to 16 bit DAC? | chris719 | Digital Source | 5 | 18th June 2005 05:24 PM |
| use digital attenuation to improve 16-bit CD playback on 24 bit DAC | capslock | Digital Source | 7 | 8th April 2002 11:18 PM |
| Page generated in 0.11171 seconds (79.14% PHP - 20.86% MySQL) with 10 queries |
