How to amplify an Amplifier !? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th June 2010, 05:39 PM   #11
Mooly's Avatar
Originally Posted by janneman View Post
Great idea Mooly! The scart is standardized, no? Should have the info somewhere on the 'net.
Edit: bingo: SCART (Peritel; Euroconnector) pinout and wiring @ pinouts.ru
jd
It is standard yes
Installing and using LTspice IV. From beginner to advanced.
Old 9th June 2010, 05:51 PM   #12
Galgo is offline Galgo  Israel
From looking at the manual (the link above) i'm not sure it actually output sound through the SCART - is it possible?
Anyhow - I can check it pretty easily next time - just see if connecting the SCART to the TV gives any audio from the TV speakers as well...
What about the "cable" question?
Gal
Old 9th June 2010, 05:55 PM   #13
Mooly's Avatar
Gal
Remind us what question ?
Old 21st June 2010, 08:31 AM   #14
So - SCART was a GREAT idea - only one problem, the model distributed locally has NO SCART output
So I'm back to using the only output from this damn unit - which is also the worse possible - using the front Speaker out terminals...
So just to verify again - what are the recommended resistor values I'll need?
Would using a standard 50K/ohm STEREO audio pot be suitable (I have few of these around) ?
What level of current/Watt it should be able to handle?
Or should I rather use single resistor in-line before the amp ?
I'd rather control the volume from the device instead of having a separated pot - and there is a built-in option to set all the channels volume separately - so shouldn't be that hard to balance the rest with the "bi amplified" Front channels...
Jest please recommend the "less worse" solution and specific components I should use...
Gal
Old 21st June 2010, 09:36 AM   #15
P=U^2/R,you know P and you know R so you can roughly figure what Uout of the reciever will be. add some and the calculate the resistor devider you need to go to line level (i use 1.41 volts, but that's not the standard afaik) when the output is at maximum.
now choose a resistor range; i'd use something in the 10K range. with the same rule (now you know Uout) you can calculate what power rating the chosen resistors should be.
Old 22nd June 2010, 11:48 AM   #16
What is the standard V I should aim for regular line level?
Can you help me calculate - I lost you a little bit (sorry for my NEWBEness) - The details above are all I have...
Gal
Amplify my 4 ohm speaker .sQuare_nl Solid State 13 6th February 2009 10:41 AM
weak input signal to amplify pra3718 Chip Amps 2 14th January 2009 03:29 PM
How to amplify a tweeter and midrange nickvda Multi-Way 4 11th July 2005 09:46 AM
Amplify weak signal to stronger... Mikka Solid State 18 8th June 2003 04:12 AM
i want to amplify my telephone travis Everything Else 8 13th May 2002 06:36 PM
Copyright 1999-2017 diyAudio
