Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
LED display shining through the wood
Old 26th May 2010, 02:31 PM   #1
Cassiel is offline Cassiel  Libya
Default LED display shining through the wood
I like this idea for a DIY amp, but I don't know how it works. Any ideas?
Shine Labs Woodblock Clock ICFF 2010 | Apartment Therapy Unplggd
Old 26th May 2010, 03:05 PM   #2
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
It's a bit hard to tell from the pix but I would guess that the wooden face is routed out from behind to leave a very thin layer into which the LED display is mounted. If you were going to attempt this I would rout out from behind leaving maybe 1/16" of wood thickness, then use clear epoxy to glue a clear 1/8" lexan window into the recess to reinforce the thin wood layer. Then I would use a jointer set to take about 0.005" per pass (or sand if you don't have a jointer) from the outside face with the LED display in place until the wood was thin enough to let the display show through as you want. It would be a delicate operation but I think doable. Good luck!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 26th May 2010, 03:15 PM   #3
Thanks! That was a great reply.
Old 26th May 2010, 03:41 PM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
It says right on the ShineLabs website that it's just a thin cut veneer.
Seemingly magical and with a presentation as natural as wood itself, the Sonic Woodblock Clock incorporates a one inch high LED time display that shines through a thin cut wood veneer face.
Old 26th May 2010, 04:43 PM   #5
Thanks for the info, anyway I am happy to have missed that as am going to use solid wood. I believe if I follow kevinahcc20 instructions it will also work. Besides, I couldn't do the finish as good as the one in the pic using a thin cut veneer.
EDIT: I just tried it with a piece of solid rosewood. A bright white LED gives red color. :-)
Old 26th May 2010, 05:15 PM   #6
Pano is offline Pano  United States
Pano's Avatar
It's a very cool idea. Let us know how it goes for you.
Old 26th May 2010, 05:37 PM   #7
wrenchone is offline wrenchone  United States
wrenchone's Avatar
If a bright white LED shows red through the rosewood, you should probably start with an ultrabright red display to begin with. The white led is a combination of a blue LED with yellow phosphor - what red there is in the fringe of the yellow phosphor's emission. A red or orange LED will end up brighter.
Old 27th May 2010, 12:31 AM   #8
mickeymoose is offline mickeymoose  Canada
Neat indeed! Lasercutting could get it within 0.005", just do not breathe on it!
Old 27th May 2010, 01:23 PM   #9
Panomaniac, it has worked out well, but it's a very delicate operation - no room for mistakes! Will post pics once the amp is finished.
[QUOTE]just do not breathe on it!/QUOTE]
I won't, paper thin.
Wrenchone, the LED I'm using is transparent, it gives a bright white light but through the wood it looks like a red LED. With a superbright red LED I expect to get dark blue or purple but maybe you're right -will buy some and try them.
Old 27th May 2010, 08:32 PM   #10
EBM_dude is offline EBM_dude  Germany
EBM_dude's Avatar
Is this link Solid Wood Digital Clock helpful for you?
LED display shining through the woodHide this!Advertise here!
Replacing a VFD Display with LEDīs - possible? Salar Everything Else 5 12th February 2009 07:51 AM
Sheilding from Numerical LED display. henkel Parts 18 22nd October 2008 06:27 PM
Replacing an EL display with an LED one. neutron7 Parts 0 21st June 2008 04:56 AM
WTB: Digit LED display JoshK Swap Meet 0 19th June 2006 04:19 PM
2 1/2 digit LED display bstanton010 Parts 0 14th September 2005 05:30 PM
