Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th June 2003, 03:33 PM   #1
protos is offline protos  Greece
protos's Avatar
Default How do you solder soic packages?
I was wondering how difficult it is to use "soic" chip packages for diy and what is the best method to solder them
Old 20th June 2003, 05:06 PM   #2
mwmkravchenko's Avatar
Default How god re your eyes?????
Yep you can use them. Your boards will have to be designed for them or you can make (preffered) or shudder the thought buy adapters for the little gremlins. Life is easier with the right equipment but there are ways to do it.
to make an ultra small iron tip wrap some solid core bare wire around your tip and extend the coil around a couple of turns for it to stay in place. Extend the new "tip" past the existing tip and lightly tin the whole mess to promote good heat transfer. An adjustable temp iron is also good if not esential. If you don't have this maybe a variable transformer or even an appropriately mounted light dimmer from home depot or where ever.
Next very thin solder, good paste or even better solder paste.
An illuminated magnifying lamp is good for us squinters. A very adjustable hot plate is good when you are doing larger jobs because it alows you to preheat your board to just under the melting point of your solder and you can work more quickly.
One big caveat.. HEAT KILLS so you need to work fast and face the cruel hard fact that you are going to kill something some time when you are starting out. But it gets better with practice
Mark
Old 20th June 2003, 05:59 PM   #3
jackinnj's Avatar
if you don't want to make a major investment, get a 12 watt soldering pencil. Lightly tin the board traces, tack down one leg of the device (holding it with a tweezer -- it won't move afterward) and then just proceed along.
SMT saves a lot of drilling!
I posted a link to www.stencilsunlimited.com a few days ago -- this is a great idea if you are doing a lot of prototypes. Uses a stainless steel stencil, solder paste and a toaster oven to accomplish the same end.
Old 20th June 2003, 06:24 PM   #4
JOE DIRT®'s Avatar
Both ideas work good....it seems all my protoyping chips are coming surface mount now
Old 20th June 2003, 06:42 PM   #5
nobody special's Avatar
If you're doing all surface mount, you can use a toaster oven to reflow. We do it on prototypes where I work all the time.
Nobody
Old 29th May 2004, 08:31 AM   #6
i'm sorry but i don really know about those things.can u pls explain it more detaily and simple?
thanks.i'm kinda new in this.
Surface Mount Packages cantskienuf Parts 0 6th November 2008 08:02 PM
AutoCAD of tube Packages? Zero Cool Tubes / Valves 4 31st August 2008 06:15 PM
PCB Design Packages speakerguy79 Solid State 3 10th December 2006 06:32 PM
layout / component packages metebalci Parts 5 9th June 2004 04:36 PM
Insulating TO-264 packages mbroker Parts 5 13th December 2002 04:50 AM
Page generated in 0.08344 seconds (73.18% PHP - 26.82% MySQL) with 10 queries
