Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th May 2010, 03:17 PM   #1
Default Hertz changer
Hello there space travellers!
I'm having a problem understanding how to change hertz frequencies. Doesn't Voltage change the amlitude but how do I change the time period? current? I know I can change it with a resistor in a electric circuit but what am I actually doing with the resistor, am I voltage dividing or current dividing or something completely different?
cheers from Volcanoland!
Old 18th May 2010, 04:34 PM   #2
Steerpike's Avatar
Originally Posted by Tympanic View Post
but how do I change the time period... I know I can change it with a resistor in a electric circuit
No you can't. The only way to change the frequency of an AC signal is by a process called heterodyning, where you multiply it by an additional AC signal. Wikipedia will explain the details.
Steerpike's Toybox
Old 18th May 2010, 05:22 PM   #3
Great! that's what I've been looking for. so when you're changing the pitch in oscillators is that based on the heterodyning principle?
Old 18th May 2010, 05:28 PM   #4
Well that's an oversimplification. There is a whole pile of methods to create a new frequency. Oscillator, synthesizer, heterodyne, and more. They are all inefficient and complex.
I suggest you get a motor and a generator and connect them with a variable ratio gearbox. A bit noisy and unstable but it works. Or develop what is called a quasi-sine wave (better known as some strange waveform that doesn't resemble a sinusoid) with switching transistors controlled from a crystal controlled frequency synthesizer.
Old 18th May 2010, 05:48 PM   #5
Steerpike's Avatar
Well we dont know WHAT frequency Tympanic is trying to change. Is it mains waveforms? Is is a musical instrument tone? Is it a radio frequency? Is it a DAC clock?
Strictly speaking, oscillators & synthesisers don't change the frequency - they create a new wave from scratch - which may be created in such a way as to track the original in a modified way.
Heterodyning does it by physically altering the original waves shape through sinusoidal multiplication.
Some oscillators - such as older test bench oscillators- use heterodyning because if low freqency outputs are needed, two high frequency oscillators provide a more stable and cheaper solution than to build a true low frequency oscillator.
Radios, TV sets, almost all communications receivers, use heterodyne oscillators to recover the high frequency broadcast wave.
Heterodyning is also used in organs and guitar effect pedals to create vibrato.
If you have a simple single frequency oscillator (a Hartley or Colpitts oscillator etc), they oscillate at a particular frequency because of the resonance of the LC tank circuit. A capacitor+inductor combination has a natural frequency at which it 'rings'. Altering either component in the tank changes its natural frequency.
A Wien bridge oscillator is somewhat different: Wien's bridge is a network of capacitors and resistors that has a specific phase shift depending on the freqency. If you design it right, you can create a feedback loop where you get reinforcing feedback (i.e., the phase of the feedback is right to reinforce) which promotes amplification, then oscillation, at only one frequency
Steerpike's Toybox
Old 18th May 2010, 09:32 PM   #6
I have an old ring modulator unit from the early days of 'musical' synthesizers. It shifts the frequencies of the tones. Really a stupid idea but they sold them, and now I find myself with one in nice condition. Using it is out of the question for me, since I consider myself a musician.
Old 18th May 2010, 11:10 PM   #7
Steerpike's Avatar
Not such a stupid idea I think. Ring modulators we (are) a core building block of all analogue synthesizers such as the Moogs, and even the semi digital ones like Roland's "Linear Algorithmic" series like the famous D50. Or are those the very 'instruments' you disdain, being a musician???
Oh and it is the primary tone generator in any Theremin.
What you can do with a ring modulator ON ITS OWN is a bit limited I guess... unless you have an original Moog to patch it into.
Steerpike's Toybox
Old 18th May 2010, 11:36 PM   #8
Yeah I confess to not liking this electronic trend in instruments. I finally broke down and bought an electronic piano only because nobody has pianos any more. But I can't hear any musicality in the output of a modulator.
Maybe my modulator has historic value.
Anyway this is off topic to some extent.
Old 19th May 2010, 10:52 AM   #9
brilliant,,, thanks allot guys. well the frequencies that I'm planing to change is both guitar tone and also I'm planing on making some oscillators and even blend it all... I'm really new to this but this is too exciting!!!! I just really wanted to know why the pitch changes when I turn the potentionmeter and understand more what I'm doing to the wave by adding/removing resistance and such and such,,,, now I know more what to look for...... I've got allot of reading to do
cheers from Iceland
Old 21st May 2010, 12:42 AM   #10
Guitar Pitch Shifter - Pitch shifting
4 Band Pitch Shifter
BossArea - Boss PS-3 Digital Pitch Shifter/Delay
Audacity will do it for already recorded signals
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
taking a W3-871S to 80 hertz Douwe Full Range 86 30th October 2009 06:08 PM
Help!...it hertz crick Full Range 9 2nd July 2007 08:34 PM
Zero hertz jaberwocky6669 Multi-Way 36 16th June 2007 03:59 AM
Hertz ML-5400 D make72 Subwoofers 14 14th January 2005 04:50 PM
Hertz or Cycles? Bob2 Everything Else 10 9th June 2003 11:50 PM
Page generated in 0.14255 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
