help me stay alive (mains) - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th June 2003, 05:04 AM   #11
Send a message via AIM to travis
how much wire do you overlap when you are soldering two wires together? do you twist them together real good like?
donuts
Old 20th June 2003, 05:12 AM   #12
karma is offline karma  Canada
karma's Avatar
sure if you wana rap it sounds good. im lazzy i overlap and solder
Old 20th June 2003, 08:54 AM   #13
Default Re: help me stay alive (mains)
Originally posted by travis
i got this neat toroid and i need some suggestions on connecting it to this power cord i have. just solder and heatshrink? seems kind of weak.
Soldering mains-voltage connections is a bad idea. Here in
Sweden it is illegal to do so. A solder joint may melt from
overheating in overcurrent situations, the joint will start
to turn into a non-connection and you may get mains-voltage
sparks that can cause fire.
Usually some form of screw-terminal connections approved for
mains-voltage use is the solution.
JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) Paradise_Ice Swap Meet 11 10th June 2013 02:02 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
stay-on switch CommanderZero Parts 0 17th June 2006 09:51 AM
Dr. Bob says: Don't be a fool stay in school Fred Dieckmann Everything Else 1 1st April 2003 10:31 PM
Copyright 1999-2017 diyAudio
