| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I bought some AC 450V analog volt meters but on arrical discovered that I should have gotten direct current.
I opened one of them and It seems it have an internal rectifier. First a 2W 180k resistor, then two parallel, opposing diodes with one smaller resistor each. So, there seems to be a sort of rectifier integrated in the meter. But, what happens to the range when I remove the rectifier? Is it a stupid question? It it just a matter of adding resistors until I get the 450V range back? |
#2 |
Usually an ac meter has lower sensitivity so it will draw more current. Is the scale linear? Most ac meters have the scale crowded near the bottom although yours are high enough range that they probably are linear.
You don't have to remove the rectifiers; it should work on dc but you may need to recalibrate. |
#3 |
Jepp the scale is linear.
it´s one of these: High Quality Round Analog Volt Panel Meter AC 450V on eBay (end time 16-May-10 06:05:24 BST) |
#4 |
There is no mention of the burden but I'd imagine it would draw a mA or as much as 5 mA at full scale.
So apply a known voltage and adjust the internal multiplier until it reads correctly. Use good quality resistors or you might have some temperature drift. And be careful; these voltages are hazardous! The most difficult part would be changing the dial to read DC instead of AC. |
#5 |
Thanks for the input. I´ll use the tube amp I am building for reference voltage, with a multimeter, and see if I can find the right resistor values and adjustments for using the scale thats on it. I will use it in the 250V area.
Go slow, one hand in back pocket, the secret sign of the DIYaudio guild! |
#6 |
Problem solved!
There was a tiny potmeter in the circuit. It had sufficient range to adjust the voltage. Thanks for info and psychological support Bob! |
#7 |
Couldn't be easier! Good luck.
| Ooops! Bought a three phase bridge by accident. | seabass23 | Solid State | 1 | 13th March 2010 05:08 PM |
| 9v. 350ma.dc. class2 ac-dc wall adapter question | crippledchicken | Power Supplies | 1 | 26th October 2009 04:39 AM |
| we can offer power module of DC/DC Converter & AC/DC Adapter | auling | Vendor's Bazaar | 0 | 12th May 2009 03:48 AM |
| 12v dc to 19v dc and 110v ac | shadiedog87 | Power Supplies | 0 | 18th December 2007 02:57 PM |
| Combined PFC AC/DC & DC/DC SMPS | ChocoHolic | Power Supplies | 33 | 22nd December 2005 10:04 PM |
| Page generated in 0.10986 seconds (64.93% PHP - 35.07% MySQL) with 10 queries |
