Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th May 2010, 09:40 AM   #1
Default Technics And Bi-wireing
Hi, my technical knowledge is little so please forgive if I seem to be asking for help when the answers are obvious, or if I have posted to the wrong forum.
I am hoping some one can help with a problem I currently am facing.
Existing Technics SUVX500 amplifier is intermittently failing, after 19 years of faultless service the voltage control light goes off and the sound goes off with it.
I also have a Technics SU-V4X which is working fine.
The existing Technics SUVX500 is bi-wired to a pair of Tannoy 607 speakers, using the bi-wire position on the speaker selector switch. (Speaker selector switch has “A; B; Off & bi-wire positions)
I want to bi-wire the SU-4VX to the Tannoys using both sets of speaker terminals. This amp' has push button speaker selector switches marked "Main and Remote", no mention of bi-wire.
Both amplifiers have two sets of speaker outputs.
The questions are:
  • Should I have both Main & Remote switches on when using the speakers bi-wired
  • Is it actually possible to bi-wire the SU-4VX as the impedances / switching given in the specifications differ from the SUVX500.
I’ve listed some of the specifications below.
Load Impedance:
Su VX500 SU V4X
A OR B, BI_WIRING 4Ω_16Ω Main OR Remote 4 Ω – 16 Ω
A AND B 8Ω_16Ω MainAND Remote 8 Ω – 16 Ω
TANNOY 607 Speakers
Nominal Impedance 8 Ohms
Minimum Impedance 6 Ohms
Sorry, if I’ve been long winded and thanks to anyone who has taken the time and trouble to read this.
Old 5th May 2010, 10:14 AM   #2
You will want both the main and remote buttons pressed - this is the same as the 'bi-wire' setting on your other amp.
The amplifier will see the same overall load impedance if the speakers are biwired or single wired, i.e. it will still be nominally 8 ohms either way.
Old 5th May 2010, 12:57 PM   #3
Many thanks, Ben.
You're help is greatly appreciated.
Geoff.
Humbucker into Tele but need wireing diagram??? ERiCARDEN Instruments and Amps 1 11th December 2009 07:28 PM
Help with some speaker wireing please.... Minion Multi-Way 5 7th December 2008 01:01 AM
Please Help With Wireing My Cab!!! Dtorre Instruments and Amps 5 19th July 2007 09:27 AM
DIY attenuator (was silver wireing) Magura Parts 7 19th March 2004 02:05 AM
Help with Tranny Wireing. jleaman Solid State 7 28th January 2003 04:51 AM
Page generated in 0.08181 seconds (73.99% PHP - 26.01% MySQL) with 10 queries
