Have you checked the outlets at your home for proper wiring? You can buy a little plug thing w/ LEDs at Radio Shack, Home Depot, Lowes, etc which will tell you if the ground is OK and if the hot/neutral wires are correct.
Cheers, Jim
GB Electrical model GRT-500A. Anyone that routinely walks into an unknown line situation (electrician, pro audio) should probably have something similar. It wont tell you everything but it will tell you, whithout having to thing much, whether something is wired wrong.
